Fuel smell
So that I can eliminate this as a problem how can I test the valve? Does it work off 12v or a different voltage as it is controlled by the ECU?
- SundanceUK
Also check that the fuel pipes to the filter and injector rail are not leaking. They are on push fit connectors, may need to be cracked and re-seated, or the o-rings replacing.
I had the fuel smell in the cockpit once on my 160, and also lost the pressure out of the system. Strangely after a couple of days, it sorted itself out.
Sundance
I'd still be interested to know how to test the purge valve if anyone has done this before? Is it 12v or less - I don't want to risk damaging it by applying the wrong voltage.
When I took the fuel pump out, the pin you can see loose fell out
So it appears that at some time the pin has got hot ( I assume due to a poor electrical contact) and damaged the plastic holding the pin, leading to it becoming loose. So I've put shrink Insulation on the damaged part of the cable, polished the pin, and potted the cable pins on the inside of the pump lid with Araldite.
So once it is back together we'll see if that has sorted it.
If you lubricate the seal before refitting, it makes the job much easier...
Will likely be in a similar "burnt" condition.
Also if poor connection caused the over-heating, then the pin connector (receptical) might be "oversized" and need squeezing together to re-gain a tight fit on the pin, otherwise same fault might return.
Dont want hot cables and petrol mixing!!!
- SundanceUK
Sundance
SundanceUK wrote: Should be able to get a good second hand connector from MGFnTFbitz..
Sundance
Just carefully take the female pins out of the connector block, there’s a small barb just below the wire, clean em up and give them all a gentle nip, slip them back in and it should do job and you have nothing to lose lol..
- SundanceUK
The cost of a second hand plug would be next to nothing, replacing the plug would be a no brainer for me.
As an industrial electrician, have seen many burnt plugs and sockets in my time. Nearly all needed replacing. The only good side is you are only feeding 12 volts (ish) to the connector, so tracking across any pins may not be as bad as the 24v that is the industry standard now.
The last thing you need is sparks and flames close to the fuel lines.
Sundance
