MGTF Wheel Bearing Query
MGTF Wheel Bearing Query was created by g4wam
Posted 6 years 2 months ago #187672
Hi folks,
just wondered if anyone might cast some light on the following issue I have with my MGTF.
My rear NS hub has a lot of up and down movement and a small amount of side to side play, cant feel anything in the bushes but the hub and the brake disk assembly is moving in sympathy with the up and down movement.
The opinion is that it is a wheel bearing problem ( but the ususal sound is not present when the whole rear wheel is spun)
Could it possible be play in the hub carrier and not the bearing?
Any comments would be gratefully received
thanks
Mike
Last Edit:6 years 2 months ago by g4wam
Last edit: 6 years 2 months ago by g4wam.
Replied by David Aiketgate on topic MGTF Wheel Bearing Query
Posted 6 years 2 months ago #187674
Could be. A worn bearing can damage the hub so that even a new bearing won't fix the problem.
The following user(s) said Thank You: g4wam
Replied by Calico10 on topic MGTF Wheel Bearing Query
Posted 6 years 2 months ago #187676
Your symptoms sound exactly as mine was. That was the wheel bearing. New bearing fitted and problem solved. It could be that the bearing has worn so much that it has damaged the hub, but i would have thought you would have noticed a deterioration in the handling before it got to that point. Best regards Dave
Replied by g4wam on topic MGTF Wheel Bearing Query
Posted 6 years 2 months ago #187680
thanks you for your reply-the fault did not appear on the MOT in July last , so possibly a new bearing will fix the issue.
Mike
by g4wam
Time to create page: 0.479 seconds
