Crankshaft pulley bolt - standard or deep socket required?
Crankshaft pulley bolt - standard or deep socket required? was created by Gavin207
Posted 6 years 2 months ago #187673
Next job on my TF is replacing the water pump and timing belt. I've seen mention of possibly needing a deep 22mm hex socket, or can a standard 22mm socket be used?
1.6 engine without AC etc, and I'll be locking the crankshaft via the flywheel using the service tool.
Thanks.
Thanks.
by Gavin207
Replied by David Aiketgate on topic Crankshaft pulley bolt - standard or deep socket required?
Posted 6 years 2 months ago #187675
Standard is fine
The following user(s) said Thank You: Gavin207
Replied by talkingcars on topic Crankshaft pulley bolt - standard or deep socket required?
Posted 6 years 2 months ago #187700
but hex is good.
by talkingcars
Replied by Gavin207 on topic Crankshaft pulley bolt - standard or deep socket required?
Posted 6 years 2 months ago #187704
Thanks both - picked up hex impact socket and alternator belt from Eurocarparts ( plus OAT coolant at £18.99 for 5L concentrate which seems a good price), timing belt, waterpump, cam lock and flywheel lock arrived from Rimmers, so all set to start on her this evening ( cars are all female for obvious reasons aren't they )
by Gavin207
