Brake system fluid capacity
Brake system fluid capacity was created by Gavin207
Posted 6 years 2 months ago #187839
i'm got to bleed my brakes as i removed the sub-frame to clean / protect it, so am going to take the opportunity to replace the system brake fluid using my trusty Eezibleed ( assuming i have a cap that fits :) )
Does anyone know how much fluid it will take to bleed the whole system and replace the fluid? if i put 500ml through the system, will this have replaced it all?
Replied by cairnsys on topic Brake system fluid capacity
Posted 6 years 2 months ago #187840
Sorry, can't see anything in the workshop manual about brake fluid capacity. All the other fluids but not brake system :(
Replied by sworkscooper on topic Brake system fluid capacity
Posted 6 years 2 months ago #187841
Hi Gavin . I think that sounds to be a bit on the skinny side . I bought a 1 ltr bottle to do mine last year . The reservoir takes quite a bit and assuming that you have ABS it will take more to fully flush out the system .
John
Replied by davidgv1 on topic Brake system fluid capacity
Posted 6 years 2 months ago #187842
Hi,
I have just had a look at the Rimmers “how to?” They recommend using 1 Ltr, the system is about a 1 ltr capacity.
From this demo, they use a pressurised unit, and take 250ml from each corner, flushing through the old fluid.
Cheers
Replied by Gavin207 on topic Brake system fluid capacity
Posted 6 years 2 months ago #187843
Thanks all - a litre it is then. I'll probably take a bit more from the rear cylinders than the fronts, to allow for the longer lines.
Replied by SundanceUK on topic Brake system fluid capacity
Posted 6 years 2 months ago #187844
I would get at least half as much again, as the brakes can take a couple or three attempts when bleeding them, especially if you have four pots.
Sundance
Replied by talkingcars on topic Brake system fluid capacity
Posted 6 years 2 months ago #187850
There is a single line front to back.
With ABS the correct sequence is
Off side rear
Near side rear
Near side front
Off side front
The Gunson kit doesn't have the correct cap, I made one from a scrap master cylinder.
Last Edit:6 years 2 months ago by talkingcars
Last edit: 6 years 2 months ago by talkingcars.
Posted 6 years 2 months ago #187855
Flushed the brakes through today, using my Eezibleed. Unfortunately the caps supplied with it only fit reservoirs with screwed caps. They sell a universal cap but it costs almost twice as much as the Eezibleed! So I've made my own.
I run it off my compressor, and find 10psi is plenty.
Last Edit:6 years 2 months ago by Gavin207
Last edit: 6 years 2 months ago by Gavin207. Reason: Typing error
The following user(s) said Thank You: David Aiketgate, sworkscooper
Time to create page: 0.844 seconds
