Which servo bracket?
Which servo bracket? was created by NikTheGeek
Posted 6 years 1 month ago #188059
I've decided my brake pedal is a little spongy. So as well as replace the fluid and therefore bleed the brakes, I was also looking at a servo bracket. But I can see 2 types: The MG Mania one and the Mike Satur one
http://mgmanialtd.com/index.php?id_product=887&controller=product
and
MGF. MGTF RHD.Uprated Brake Servo Brace Kit Mike Satur design
Completed
For a 2004 TF, which one is the best one to get?
thanks
Nick
Replied by cairnsys on topic Which servo bracket?
Posted 6 years 1 month ago #188060
I have the one that was previously marketed by Jaylad and looks suspiciously like the mgmania one. Seems to work fine.
Replied by Fisher on topic Which servo bracket?
Posted 6 years 1 month ago #188063
Hi Nic
I fitted the Mgmania bracket earlier this year. An extremely solid piece of kit, but you do need flexible joints in your wrist to tighten some of the bolts.
Robert
by Fisher
Replied by mgtfbluestreak on topic Which servo bracket?
Posted 6 years 1 month ago #188068
I was going to try the mike satur one...when/if I get around to it.
Last Edit:6 years 1 month ago by mgtfbluestreak
Last edit: 6 years 1 month ago by mgtfbluestreak.
Replied by VX54NEW on topic Which servo bracket?
Posted 6 years 1 month ago #188070
I have the MG Mania bracket.easy to fit,no major dismantling of car and no drilling.
Does the job intended,nice firm pedal.:broon: :broon:
by VX54NEW
Replied by SundanceUK on topic Which servo bracket?
Posted 6 years 1 month ago #188071
Sourced mine from MGFnTFbitz, nice and solid with a good durable powder coat finish. Came with stainless bolts.
Sundance
Replied by NikTheGeek on topic Which servo bracket?
Posted 6 years 1 month ago #188096
Got my MGMania bracket in stainless steel. Does look like a nice bit of kit. Only just arrived at work today so not fitted yet. However, I did bleed the brakes yesterday and treated it to new brake fluid and it hasn't helped. I still can't get the car to lock up when doing 60/70 and slamming on the anchors. I never have had it lock up on a nice dry road, only ever in the rain. I'm sceptical that the bracket is going to make that much difference, but we'll see.
Any other ideas apart from new discs and pads? The discs are new, but just Eurocarparts ones and the pads are only a thousand miles old or so and are Pagid ones.
Nick
Replied by sworkscooper on topic Which servo bracket?
Posted 6 years 1 month ago #188097
Hi Nik.
That's very much the same as mine and is how the smaller brake set up is . As most on here will tell you, the pedal will feel much firmer with the brace fitted but it won't do much else . I felt the same when I compared it to the performance of our daily run about .
John
Last Edit:6 years 1 month ago by sworkscooper
Last edit: 6 years 1 month ago by sworkscooper. Reason: Missed a bit
Posted 6 years 1 month ago #188101
Nik, I fitted 280mm discs from MGFMania (not mgmania!) all round to my F and I can get the wheels to lock under very severe braking now. No abs fitted to my car.
I have Pagid pads as well so nothing special there.
Posted 6 years 1 month ago #188112
I never noticed the subtle difference between MGmania and MGFmania. Despite having had my glass window fitted at the latter. I did wonder why he didn't have a brummy accent now you mention it!! :)
Thanks, I'll take a look!
Posted 6 years 1 month ago #188154
Or make your own
Last Edit:3 years 3 months ago by mgtfbluestreak
Last edit: 3 years 3 months ago by David Aiketgate. Reason: Correction
The following user(s) said Thank You: David Aiketgate, Bob, SundanceUK, Gavin207
Replied by davidej on topic Which servo bracket?
Posted 5 years 7 months ago #190151
I have got an MGF with the older type of air intake ie pre-"schnorkel"
i understand the MGmania type will not fit unless I update the intake also.
From my non-expert point of view this seems a better solution than the Mike Satur type as it ties the servo into a rigid seam in the bodywork.
Is it worth the roughly double cost to get the MGmania type and schnorkel intake?
PS I almost never go out in the rain so the better waterproofing of the schnorkel is not an issue.
by davidej
Time to create page: 1.577 seconds
