Hood with fixed glass window - advice please
Hood with fixed glass window - advice please was created by Gavin207
Posted 6 years 1 month ago #188147On the third hood bow I've removed the 7 bolt bar that fixed the hood, and the riveted bar that fixed the window zip. I assume neither is replaced, and the hood isn't fixed to the third bow, so that it separates from the bow when folding the hood, and sits flat on the rear shelf when folded?
Replied by talkingcars on topic Hood with fixed glass window - advice please
Posted 6 years 1 month ago #188148
Replied by David Aiketgate on topic Hood with fixed glass window - advice please
Posted 6 years 1 month ago #188160The later glass screen hoods were made so that they were a straight swap.
Mine is a later version and was a straight swap.
So the shape and size of the glass is important.
Posted 6 years 1 month ago #188161David
Replied by Gavin207 on topic Hood with fixed glass window - advice please
Posted 6 years 1 month ago #188164I understand that when fitting a glass window hood to a car that had a PVC rear window, additional webbing needs to be fitted between the third bar and the lower fixing bar, to support the additional weight of the glass? if this is the case, does anyone have any details / images of where / how this is fixed? i believe it is riveted to the the third bow, and then trapped under the rivets fixing the back of the hood?
- adamelphick
Replied by adamelphick on topic Hood with fixed glass window - advice please
Posted 6 years 1 month ago #188166David Aiketgate wrote: If I recallcorrectly, Adamelphic fitted a first generation glass hood and detailed the work involved on the forum.
That was me! LOL That hood now lives for posterity with MG Mania!
It was a faff - you have to release the rear top bar, fix the zipped part directly to the hood itself, then add the right length straps between the rear top bar and the rear lower bar (essentially to pull the top bar backwards) - i am hoping it's all still in the How To's here?
Found it but all the pics are gone: https://www.the-t-bar.com/forum/25-adamelphick-s-guides/840-glass-rear-screen-how-to-fit-in-a-mk2-hood
- BruceTF135
Replied by BruceTF135 on topic Hood with fixed glass window - advice please
Posted 6 years 1 month ago #188171All of the necessary straps came in the kit, along with the heater wire, rivets etc.
I've never fitted a hood before but I took my time and it came out OK. It took most of a weekend but if I did it a second time it would take much less.
The biggest problem I found was closing the hood again afterward. It was tight and took some stretching.
Be prepared to have to adjust the side windows etc after fitting.
Replied by mowog73 on topic Hood with fixed glass window - advice please
Posted 6 years 1 month ago #188172Gavin207 wrote: I understand that when fitting a glass window hood to a car that had a PVC rear window, additional webbing needs to be fitted between the third bar and the lower fixing bar, to support the additional weight of the glass? if this is the case, does anyone have any details / images of where / how this is fixed? i believe it is riveted to the the third bow, and then trapped under the rivets fixing the back of the hood?
Yes, the additional webbing is the Support Strap Upgrade Kit - for Glass Window Hood - Pair - DSD000030PMASKIT and is presently 25% off at Rimmer Bros.
[size=10pt]Mark[/size]
95 MGF
- adamelphick
Just cut up an old seatbelt and use that for free!
Posted 6 years 1 month ago #188174Please Log in or Create an account to join the conversation.
