not so quiet - blown head gasket
Replied by David Aiketgate on topic not so quiet - blown head gasket
Posted 6 years 3 days ago #188562At least there's no problem with diagnosis. That's me desperately looking for a positive...
- sworkscooper
First thoughts ( before i crawl underneath) is that if there is emulsion in the expansion tank the head gasket went first, as if it had just dumped coolant first, then emulsion wouldn't have had time to form? ( not that it really matters!)
Next thought - it's an opportunity to fit a re-manufactured engine, and give the car a longer life, rather than replacing the head gasket on an 90,000 mile engine which has previously had the head skimmed. Bodywork is very good, no significant rust and i've added Dinitrol to all the places Rover didn't.
All views welcome.
- sworkscooper
John.
- SundanceUK
Gavin207 wrote: Yes that's an option. i suppose I'm thinking that an engine with 90k on it will have limited life left in it, so a good quality remanufactured engine with new shells, liners, etc. should be like new, and give me another 100k? How long do people reckon the bottom end on a well maintained k series is good for?
I have seen a few with up to 150K miles on the clock, but whether those still had original engines in - probably.
Also I keep a check on the ZT's for sale regularly, and I have seen many with mileage between 170K and 220K miles.
So if you look after your K series it may have a lot more miles in it yet!
Maybe if you do a lot of driving in your motor, get the head gasket replaced - if there is no too much damage to the pistons, liners and bottom end and then source a decent low mileage or refurbed powerplant for sometime in the future. Gives you time to wait and pick up a good bargain as and when one comes available.
Sundance
Posted 6 years 2 days ago #188573If you have changed the oil and filter at recommended intervals there's no reason that engine won't potentially have loads of life in it.
Most engine damage that I know of has been caused by either timing belt failure or hydraulic locking from coolant in the cylinders.:shrug:
In this instance, what is a REMANUFACTURED engine exactly? I have personal experience of a Nissan engine, supposedly rebuilt by specialists, that failed spectacularly within 10 miles of leaving the garage!:rant:
Based on the feed back I've had, assuming the head is OK and flat, I'll aim to replace the head gasket. Challenge as I understand it amongst other things is removing the head without disturbing the liners? Also which head gasket to go for, MLS or Elastomer? I've read differing views on the gasket choice, and would appreciate the thoughts of the learned contributors to the T-Bar.
I'm also aware the choice of gasket is also determined by the liner protrusion?
- sworkscooper
Replied by sworkscooper on topic not so quiet - blown head gasket
Posted 5 years 11 months ago #188577Well I know it depends on your view on the elastomer type gasket . Having changed several of these gaskets , if I came across the designer / engineer who thought it would be a good idea to use what is nothing more than silicone sealer on a cheap and nasty piece of aluminium gasket , I would like him to justify his reason for using it. :rant: Many would say it was a cost saving exercise but whatever the reason all it ended up doing was causing the demise of many engines and ruining the reputation of both MG/Rover ( as they continued to deny that there was a problem ) plus loosing the confidence of their long suffering customer base .
MLS would appear to be the only way to go in my opinion, although some people may have a different view .
John
