TF 160 Air Filter Intake Hose
- Martinm760
- SundanceUK
Sundance
- SundanceUK
https://rimmerbros.com/Item--i-PHD103010
Or an aftermarket one that you will probably need to fit the plastic end pieces to....
https://rimmerbros.com/Item--i-PHD000650
Sundance
- Martinm760
Replied by David Aiketgate on topic TF 160 Air Filter Intake Hose
Posted 5 years 11 months ago #188648David
talkingcars wrote: What is the ID of the hose?
Go on, do tell....
I might be able to source so industrial class ducting if I know the ID.
- Martinm760
No idea what diameter of the pipes on the TF are.
Just thinking the extra concentrated air flow straight into the throttle body would help increase the engine efficiency, but would also upset the fuel to air mixture; which would probably increase the fuel consumption dramatically?
Maybe not such a good idea then?
I'm thinking of some kind of rectangular rigid duct similar to the stuff used in air conditioning installations in buildings, perhaps with a funnel of some kind to scoop the air in at the front, or is that a bit too much of an Heath Robinson job who ever he was?
I know there is a aero dynamic fairing available for the F/TF front, but this increases the flow of air under the car therefore helping to keep the engine bay cooler.
