charging issue
hi, your volt meter is not the same as mine, but, i was getting readings up and own, happened it was just the earth lead to the battery, just check your's and let me know how you get on,this is the meter i have,
by graham1
- mgtfbluestreak
- SundanceUK
Mark,
Your clip on ammeter kind of closely resembles the readings you had with your multimeter, so that suggests that one verifies the other.
I am thinking that the clamp meters probably are not as accurate at lower current measurements, say 1A or less. They do work on the electrical field generated by the current flowing in the wire. In retrospect really low current draw will be less detectable by the clamp irons and will also be more susceptible to interference from close by magnetic interference and other electrical circuits.
I usually deploy my ammeter when trying to find electrical short circuits where higher loads are present, it is ideally suited for this job. I am now convinced that anything less than 1000mA would be very hit and miss on the accuracy of my clamp meters readings. Your multimeter should be the bit of kit to trust in this little experiment.
Access to a DC clamp meter is great though and if you know how to use it correctly, you can diagnose some nasty faults very easily on your vehicles, without having to disconnect any wires. Of course anything that you suspect is lower than 10A you can use your Multimeter, I would suggest using a separate in line fuse of about 8 amps with the leads to protect the onboard fuse in your meter, which may be difficult to find a replacement.
Sundance
Sundance
by SundanceUK
The following user(s) said Thank You: mgtfbluestreak, graham1
by graham1
- mgtfbluestreak
Interesting using those meters..like to see tests like that instead of just testing voltage output.......maybe you will show us more tests in the future...like those meters you have dave.what is the insulation setting all about?
Last Edit:5 years 10 months ago
by mgtfbluestreak
Last edit: 5 years 10 months ago by mgtfbluestreak.
- SundanceUK
Wow! Thats a biggun! Yeah if it will fit...need some measurements but its nearly twice the rating of a 60A/h that I currently have.
Nearly two batteries in one!
Sundance
by SundanceUK
