charging issue
- mgtfbluestreak
..should get one in new year.
Happy new year
If you need any comparison readouts..I'm ready with the meter.
- SundanceUK
I would like to get one too...maybe next year!
Sundance
- mgtfbluestreak
- sworkscooper
Have a great New year guys , keep safe .
John
- mgtfbluestreak
- SundanceUK
I think the easiest solution is to fit a battery isolation switch, and turn it off when you know you're not going to be using the car the next day or so.
- mgtfbluestreak
Multimeter between the negative lead and battery.reading has I set the alarm.
And waiting again..drops and stays at this.(not sure how long it took to settle may of been 10sec-20secs)
Today's battery voltage is this.
I haven't any charging/battery problems but like to sniff around now and again...
There is a known issue whereby some relays do not power down on switch off...This gives a higher current drain.
The act of disconnecting the battery to insert the multimeter to check for load allows these relays to power down, hence you get a much lower current drain reading in this case
Testing the current drain without disconnecting gives a true reading.
- SundanceUK
David makes a valid point here, a shame that you cannot fire the engine up with the multimeter connected. My clip on ammeter will allow this though, so maybe my readings are more of an accurate test for now.
I would still like to see another clip on ammeter test to compare with my readings, or test another TF with my ammeter.
PS checked this morning my battery at 11.64V before I fired the engine up.
Sundance
- mgtfbluestreak
- mgtfbluestreak
Reading with alarm on.
Don't want to give anyone any false readings ...just interested how to learn how to check the electrical system using meters ...so please take in to account I'm a redneck with multimeters.
