Optimum Tracking Settings for TF - Best Performance
- chrisjglen
- Novice MGer
Optimum Tracking Settings for TF - Best Performance was created by chrisjglen
Posted 5 years 9 months ago #189370
Following on from a rebuild of the suspension set-up front and back (replace ball joints etc) I need to get the tracking done on the car.
The car is running standard suspension with 16" wheels (195 at front 215 at rear).
The car has the rear adjustable camber bars also.
I have found the following Tracking settings. Is this the best setup (or just the factory settings) or can i afford a little extra camber at the rear and a bit more TOE at the front. Suggestions please.
Last Edit:5 years 9 months ago
by chrisjglen
Last edit: 5 years 9 months ago by David Aiketgate. Reason: Clicked insert on attachment
Replied by David Aiketgate on topic Optimum Tracking Settings for TF - Best Performance
Posted 5 years 9 months ago #189373
Those figures are the front wheel settings only.
The full settings are https://www.the-t-bar.com/forum/21-david-aiketgate-s-guides/91739-suspension-settings-how-to-find-recommended.
by David Aiketgate
- chrisjglen
- Novice MGer
Replied by chrisjglen on topic Optimum Tracking Settings for TF - Best Performance
Posted 5 years 9 months ago #189380
Thank you. Are these settings the standard or can they be tweaked a little?
by chrisjglen
Posted 5 years 9 months ago #189400
Those are standard.
There has been a lot of experimentation on toe angles on the MGF but I don't know of any for the MGTF.
Time to create page: 0.515 seconds
