Gaps letting water in.. and quick questions!
- Garethcole2012
- Novice MGer
Gaps letting water in.. and quick questions! was created by Garethcole2012
Posted 5 years 9 months ago #189428
Hi all, looking for advice on an issue I can’t work out how to solve... and then a couple of quick questions if that’s ok?
1) Just changed roof and frame but still having a slight issue in that when the doors are closed, in the area Marked on the attached photo, is a gap where water is getting in.
At first I thought the seal had shifted but seemed to be the same issue with new roof in place too and seals refitted.
Anyone else had this issue and know the fix?
2) Also (probably not related), how do you fix the rattle if the windows in both sides when they are rolled down between 10% and 90% of the way? A little annoying!
3) does 2000 mgf have a power steering reservoir to top up fluid and where is that?
Hopefully not sounding like a complete dunce here!
Thanks in advance!
Thanks in advance!
Last Edit:5 years 9 months ago
by Garethcole2012
Last edit: 5 years 9 months ago by David Aiketgate. Reason: Additional info added
Replied by Cobber on topic Gaps letting water in.. and quick questions!
Posted 5 years 9 months ago #189429
In answer to Question 3: The power steering is electric not hydralic and as such there is no fluid reserivor to top up!
Replied by David Aiketgate on topic Gaps letting water in.. and quick questions!
Posted 5 years 9 months ago #189430
1 and 2 may be related.
The rattling is loose bolts on the window lift mechanism. You'll need to remove the door card and tighten up any bolts/screws you can see on the mechanism. Also grease the guide rails and swivel points while you're at it.
You could find that this stops the leak too, but otherwise you may need to adjust the fit of the glass.
There's a how to on window glass adjustment.
There is a small shaped seal that goes around the rear end of the glass at the bottom and has a plastic plug securing it to the door. Is this in place? If missing that could give a leak in the area highlighted.
by David Aiketgate
Last edit: 5 years 9 months ago by David Aiketgate. Reason: Correction
- mgtfbluestreak
Replied by mgtfbluestreak on topic Gaps letting water in.. and quick questions!
Posted 5 years 9 months ago #189451Please Log in or Create an account to join the conversation.
- Garethcole2012
- Novice MGer
Replied by Garethcole2012 on topic Gaps letting water in.. and quick questions!
Posted 5 years 9 months ago #189454
Thanks all for your help!
Both doors missing those rubber end caps, can anyone show me a pic of them in place so I can see how they should look when fitted please? Will double check in the morning and try and order some from Mgfntfbitz in Glossop...
- mgtfbluestreak
Posted 5 years 9 months ago #189465
by mgtfbluestreak
Last edit: 5 years 9 months ago by mgtfbluestreak.
The following user(s) said Thank You: David Aiketgate, cairnsys
Time to create page: 1.211 seconds
