Change coil packs
Change coil packs was created by Mac526
Posted 5 years 9 months ago #189563
Hi looking at changing the coil packs, leads and plugs on my 04 tf 135. to do a complete job what parts do I need and is there a guide to do it properly please. :-?
by Mac526
Replied by David Aiketgate on topic Change coil packs
Posted 5 years 9 months ago #189565
Interestingly, there isn't a how to but have a look at this thread. https://www.the-t-bar.com/forum/9-mgf-tf-pitstop/95833-fault-code#182436
IT should point you in the right direction.
Ps. If you'd like to make a How to we'd be happy to include it in the lists!
The following user(s) said Thank You: Mac526
Replied by mgtfbluestreak on topic Change coil packs
Posted 5 years 9 months ago #189573
Yes that link was to my post and I must add if your going to change your packs...treat yourself to some quality leads aswell..the hardest part of doing the job was taking the engine cover off......so I bought 4 plugs,2 coil packs and a set of leads...and it made a difference.and don't forget your sparkly bolts
Last Edit:5 years 9 months ago by mgtfbluestreak
Last edit: 5 years 9 months ago by mgtfbluestreak.
Replied by Mac526 on topic Change coil packs
Posted 5 years 8 months ago #189643
Good link looks pretty straight forward. can i ask what plugs and leads do you use ?
by Mac526
Posted 5 years 8 months ago #189645
When I bought the plugs in the link..they were platinum tipped plugs.
I didn't use ebay..I got them from my local motor factors...price I guess around £8 each...the leads I bought from there also.the spark plugs sit deep in the head..after removing the plastic spark plug cover you then.remove 2 small bolts for each coil pack and simply pull them out...I took a picture has always before I dismantle anything...and here is my original picture.
I can't remember what make I chose.
Once the plastic spark plug cover is off see 2 coilpacks remove the 2 bolts...should be 8mm heads on 6mm thread size....marked with yellow arrows in pic below...although I've changed my to allen key heads.
And remove the ht lead and electrical connectors from coil packs marked with the red arrows.before simply just pulling the coil pack up and out.
Last Edit:5 years 8 months ago by mgtfbluestreak
Last edit: 5 years 8 months ago by mgtfbluestreak.
Posted 5 years 8 months ago #189646
My original spark plugs were ngk/R.........pfr6n
Posted 5 years 8 months ago #189647
Found this for you?
The following user(s) said Thank You: Mac526, Keymaster, NigelOBB
Replied by NigelOBB on topic Re:Change coil packs
Posted 5 years 8 months ago #189693
I use a piece of hosepipe to remove and fit the plugs, stops you from threading them to 🤣
Replied by mgtfbluestreak on topic Re:Change coil packs
Posted 5 years 8 months ago #189694
I just use a spark plug socket on a extention bar...3/8 drive on ratchet....
Time to create page: 0.522 seconds
