Coolant drop/pressure! ?
Is this normal?
Robert
Have a new spare cap so put that on to see if it makes a difference. Will take it out for a drive tomorrow to check.
Thanks again for your input.
Robert
Cleaned the one on the car to ensure that the spring was working correctly and replaced, as this has sat for 5 months while Sorned Still fluid pressure drops. Fitted second cap fluid still drops but not as bad.
Any other other suggestions?
Have ordered three new ones!
Robert
- SundanceUK
Sundance
Did that yesterday and also to be on the safe side this morning before the run. Being a little paranoid have checked the oil for mayo and coolant for oil. None. I know these are not definitive checks, but all ease the mind.
On a 100 mile run tomorrow. Thinking should I!
Robert
Thanks guys.
Robert
When I am home I always fire it up and let it turn over for half an hour or so until the fans kick in, but last week I did the same procedure, then turned off the ignition which was the cue for the expansion cap to vent. Coolant every where!
It was getting late; so left it until the following morning, checked what I could in the pouring down rain, but there was nothing that obvious I could see.
I refilled the coolant, put a new cap on (genuine xpart I had as a spare), and the engine idled as normal, coolant level stayed the same, temperature gauge normal.
54k on the clock and original head gasket as far as I know; so I suppose the expansion cap did its job, but why it happened I don't know, now I'm thinking have I got away with it...….
Also am I right in thinking that once the cap has vented its useless putting it back on?
Replied by David Aiketgate on topic Coolant drop/pressure - Feedback
Posted 5 years 8 months ago #189775If it is overpressure then a new cap will vent also. So the old cap would be reusable once you resolve the overpressure issue. Having said that I would still go with a new cap.
However, it is much more likely that the cap itself is faulty, so a new cap will sort the problem.
What would cause "over pressure" too much coolant?
Another two ordered for spares just in case!
Posted 5 years 8 months ago #189921David
Thanks for the input just completed a 200-mile round trip after fitting new pressure cap. No problems car ran "sweet as a nut". No pressure increase or drop in fluid.
So have purchased two new caps (just in case!).
Regards
Robert
