Coolant warning label in RED!
  • SundanceUK
Coolant warning label in RED! was created by SundanceUK
Posted 5 years 10 months ago #189875
Decided to make a red coolant warming label to match my red valve cover on the engine and red fuel pump lid and red oil filler caps.
Just need to do something with my dipstick top now....bet red ones are not available.
If you want a copy then feel free to save the file from the bottom of the page...
Just copy cut out and laminate.
Sundance
Last Edit:5 years 10 months ago by SundanceUK
Last edit: 5 years 10 months ago by SundanceUK.
The following user(s) said Thank You: David Aiketgate, Bob, mgtfbluestreak, sworkscooper, Sunlover
Replied by Roverlike on topic Coolant warning label in RED!
Posted 5 years 10 months ago #189876
Dark Ice Design created Red dipstic top, see here:
Universal CNC Aluminium oil DIPSTICK HANDLE
Buy It Now
The following user(s) said Thank You: sworkscooper, SundanceUK
  • SundanceUK
Replied by SundanceUK on topic Coolant warning label in RED!
Posted 5 years 10 months ago #189879
Thank you Mr Roverlike.
Here is a scan of the original yellow coolant label in case anyone wants to re-do theirs in original livery.
Sundance
Last Edit:5 years 9 months ago by SundanceUK
Last edit: 5 years 9 months ago by cairnsys.
The following user(s) said Thank You: David Aiketgate, sworkscooper
Replied by sworkscooper on topic Coolant warning label in RED!
Posted 5 years 10 months ago #189880
More Bling Mr Sundance ! The rest of us can't keep up with you ! ! ! :rant: :coat:
John
Replied by BruceTF135 on topic Coolant warning label in RED!
Posted 5 years 9 months ago #190005
Hi, Sundance. Sorry if this seems a daft question but what diameter should these labels be printed in order for them to be the right size to fit the expansion bottle? It tried to print one out but it came out about the size of a 50p piece! :-?
  • SundanceUK
Posted 5 years 9 months ago #190007
I inserted the image into a Word document then dragged it so it was larger. I fitted two on a page one slightly bigger than the other and then printed them and then laminated them. One was pretty close to the original - pure lucky guess and it fitted straight on.
The word document is on my computer at work, if you can hang on 24 hours I will copy it over and post it up for you all.
Sundance
Posted 5 years 9 months ago #190018
If you could, that would help. I was planning to do pretty much the same - insert the image into MS Publisher and size it there. Having no original, I was unsure of the size needed.
Cheers, Bruce.
  • SundanceUK
Posted 5 years 9 months ago #190036
Red label in word format.
Sundance
The following user(s) said Thank You: talkingcars, BruceTF135, Sunlover
Time to create page: 1.177 seconds
