MGTF rear anti roll bar torgue setting.
MGTF rear anti roll bar torgue setting. was created by kpainter65
Posted 5 years 6 months ago #190448
Hi everyone,
I'm changing my dampers and springs and have got a bit lost on the torque setting for the roll bar - please see picture for what I mean. Lower damper bolt 100Nm, upper damper bolt 45Nm, but the workshop manual only specifies 35 Nm for the bolt in the picture, is this correct?
Thanks in advance
Keith
Last Edit:5 years 6 months ago by kpainter65
Last edit: 5 years 6 months ago by David Aiketgate. Reason: Inserted photos
Replied by sworkscooper on topic MGTF rear anti roll bar torgue setting.
Posted 5 years 6 months ago #190449
It looks like that is the right torque .35 nm . I tried to copy and paste using my phone to the 'How to's ' section for torque settings but I failed . :bang:
Go to that section in how to' and it gives all the settings.
John
Last Edit:5 years 6 months ago by sworkscooper
Last edit: 5 years 6 months ago by sworkscooper. Reason: Missed a bit
Replied by SundanceUK on topic MGTF rear anti roll bar torgue setting.
Posted 5 years 6 months ago #190450
I also concur - 35Nm sounds about right, I cant remember the exact figure, but I can remember its not a lot!
Sundance
Replied by talkingcars on topic MGTF rear anti roll bar torgue setting.
Posted 5 years 6 months ago #190453
IIRC you need the car on the ground on it's wheels before torqueing up.
Replied by kpainter65 on topic MGTF rear anti roll bar torgue setting.
Posted 5 years 6 months ago #190455
Hi guys
Thanks for the input, I'll go with 35Nm then.
Regards
Keith
Replied by Cobber on topic MGTF rear anti roll bar torgue setting.
Posted 5 years 6 months ago #190458
35Nm = @ 1 good grunt on a 3/8" drive ratchet handle! :bust:
Last Edit:5 years 6 months ago by Cobber
Last edit: 5 years 6 months ago by Cobber.
Posted 5 years 6 months ago #190459
So Cobber,
Preload the suspension, and a good grunt. Sounds perfect, but do I do the grunt before or after fixing the car?
Keith
Posted 5 years 6 months ago #190464
During!
Time to create page: 0.560 seconds
