SRS Light Woes
sworkscooper wrote: If after checking the wires are connected the wrong way round , when you reverse them you would be wise to check the fuses as you will have had live wires going to earth .
The air bag and pre-tensioner cables come from, and return to the SRS ECU.
Seriously, I have done everything that is recommended and even though the light goes out and stays out 99% of the time, now and again the light will pop on for no apparent reason!
A few weeks ago it came on at startup and was a constant annoyance for about 5 days. Then it went back to behaving normally without anything being done, I changed nothing in the car, no one had used the passenger seat during that time. Etc.
I was seriously considering covering the light with black insulating tape when it decided to work properly again!:shrug:
David Aiketgate wrote: I'm the only driver and the seat is bolted directly to the floor so can't be moved.
Not you David, I was talking about Salona and his exploded passenger side.
