MGTF brakes
kpainter65 wrote: ……. there are probably more F's here.
F and TF have the same brakes.
by talkingcars
The following user(s) said Thank You: kpainter65
- SALAD DODGER
- Novice MGer
Well that's really good news! If you know what make discs and pad you have fitted perhaps you can share it with the rest on here so they can buy the same products. Thanks. Steve
by SALAD DODGER
A Trophy 160 F will be pretty rare over there too I suppose. They have the 4 pots as standard. Some have Abs.
I agree that the 240 mm disc all round standard set up is only adequate at best, and then only if it is in perfect working order.:hgf:
I had some success with Ferodo premium(? something like that name) pads. They were more abrasive than standard pads and did improve the braking on my 240mm setup without being stupidly expensive.:shrug:
Edit Ferodo Premier pads
Last Edit:5 years 5 months ago
by David Aiketgate
Last edit: 5 years 5 months ago by David Aiketgate.
- kpainter65
- Journeyman MGer
Steve,
All round are high carbon disks by ttperformanceltd, 304 front and 280 rear, I don't think Neil has got any more. The 4 pot front calipers and the rear standard calipers I bought from MGnTF Bitz.pricy though.
Both front and rear pads are standard, which is why there may be a problem.
Keith
Keith
by kpainter65
Time to create page: 0.639 seconds
