Historic fault code P0500 and CVT issues
Replied by dcw611 on topic Historic fault code P0500 and CVT issues
Posted 5 years 2 months ago #191406
Further update, decided to reset the CVT using Pscan, error code P0500 cleared. Attempt to complete the Fast Adaption process, in accelerating to the 55km/h got a loud noise, engine redlined and no drive. Now looking to find a CVT specialist local to me and see what's gone wrong and how cheap a fix it is?
I assume there are more hens teeth than spare CVT units out there? Anyway fingers crossed as my usual go to mechanic is on holiday for a few more weeks.
Dave
Dave
by dcw611
- El gordo escoces
- Journeyman MGer
Replied by El gordo escoces on topic Historic fault code P0500 and CVT issues
Posted 5 years 2 months ago #191408
There is one currently for sale on eBay. Shipping costs to Australia might prove prohibitive. I got an email from ebay saying the seller was open to offers. Catastrophic failure on CVT normally means the drive belt is broken.
A wee tip when searching for CVT parts. Rover used the gearbox on other models often listed as Rover 400 45 25 mgzr ?gearbox etc. Same box( Same problems).
Please double check this information before you spend your hard earned Aussie dollars
Davy
Davy
Last Edit:5 years 2 months ago
by El gordo escoces
Last edit: 5 years 2 months ago by El gordo escoces. Reason: Removal of misleading information
Posted 5 years 2 months ago #191454
Many thanks El gordo I have emailed the seller on both eBay and the company website, but have not yet had a reply back. Is due to go into the workshop early next month, just to see how catastrophic it is, maybe they can advise?
Dave
Dave
by dcw611
Posted 5 years 1 month ago #191662
Thanks to Cobber I have located and bought a used CVT box from Allford, $1980 inc freight to Perth. My only other option was a complete rebuild at over $5K all in.
by dcw611
Replied by Cobber on topic Historic fault code P0500 and CVT issues
Posted 5 years 1 month ago #191665
Glad to have been of service :broon:
Posted 4 years 11 months ago #192090
Update
Have fitted the new gearbox, refilled the suspension and cleared warning lights on dash. thanks to pscan. Have put correct fluid in gearbox and fluid levels are good. No errors now on dash.
However gearbox is stuck now in 1st gear. Unable to reset using pscan so that fast adaptation can be performed. The P D R N etc are all good on dash display and lights work on the shifter surround. So doesn't sound like an electrical issue?
Any ideas as to what to look for. Gearbox is used but was tested I am told before delivery.
Regards
Dave
Regards
Dave
by dcw611
- El gordo escoces
- Journeyman MGer
Posted 4 years 11 months ago #192132
ROVER 25 STUCK IN FIRST GEAR
Dave, here is an email sent to a CVT owner from Z.F. the makers of the gearbox.
Common issues with the transmission in the rover application causing failure codes and car to only seemingly drive in emergency mode like being stuck in 1st or 4th in a manual car depending on which sensor is faulty.
1.... Transmission output speed sensor faulty. Replace sensor.
2.... Inhibitor switch signal corrupt due to water in the switch connection to the gearbox. Replace switch ,clean connection and reseal with silicone sealant.
3..... Ratio control actuator faulty or wiring connection to it loose on gearbox. Its the round connector on front of gearbox ) clean ,spray with contact cleaner, refit.
4.....Gearbox interface unit. Check wiring. Rear boot left side.
5..... Mix up of camshaft and transmission output sensor. Sensors look the same.
Hope this gives you something to start with; also came across this by Phillip pscan. There is an mg specialist in old Windsor called Andy Roberts. I know he has a lot of experience with stepspeeds he helped me a lot with testing of the software release that included support for it. I looked up his phone number 01753859140. Can't find email.
Good luck............. Davy
Last Edit:4 years 11 months ago
by El gordo escoces
Last edit: 4 years 11 months ago by El gordo escoces. Reason: Word missing
Posted 4 years 11 months ago #192137
Many thanks El gordo, will forward this info to the mechanic doing the work for me. Have also been in touch with the place I got the unit from so hope we can figure it all out.
Regards
Dave
Regards
Dave
by dcw611
Replied by Harry on topic Historic fault code P0500 and CVT issues
Posted 1 year 10 months ago #200965
I have a 2002 TF with an intermittent CVT ratio clutch and the same non clearable PO500. Tried a different speed sensor from another box I have and no different, Having just found this thread I thought I would change out the GIU as I have another. Same result . PO500 will not clear.
Tomorrow I will change over the CPU. I have PScanif I need to relearn the interface.
by Harry
Time to create page: 0.520 seconds
