subframe mounts
subframe mounts was created by g4wam
Posted 5 years 5 months ago #190739
I have a pair of MGF style rubber filled sub frame mounts ( front type ) as they are the same size as the MGTF solid type does anyone know if they can be modified /reused on an MGTF subframe -there are plenty of these about .
thanks
Mike
by g4wam
Replied by David Aiketgate on topic subframe mounts
Posted 5 years 5 months ago #190742
They are interchangeable.:yesnod:
Replied by g4wam on topic subframe mounts
Posted 5 years 5 months ago #190744
David,
thanks for the reply-=I assume then that I will need to fit the MGF long bolts and replace the short ones that are fitted?
Mike
by g4wam
Posted 5 years 5 months ago #190749
Seems logical.:shrug:
Replied by talkingcars on topic subframe mounts
Posted 5 years 5 months ago #190755
The solid TF mounts add to the more solid ride of the TF.
As I wanted to retain some of the compliance of the F when I fitted the TF subframes I used the F mounts.
I used the F length bolts, mostly from Rimmers but I had to source the rear bolts for the rear, I had to buy a box of 20!
Posted 5 years 4 months ago #190779
thanks Talking Cars
by the way did you need to drop one side of the rear subframe to do the rears-did you follow a How To from this forum?
Mike
by g4wam
Posted 5 years 4 months ago #190787
No Mike, I swapped subframes completely.
Time to create page: 0.509 seconds
