Head Gasket
I keep a constant eye on the temperature gauges, have fitted a low level water indicator. The oil is clean, the cooling water is as it should be.
Talking to two independent mechanics who have looked after these amazing little cars say l am on borrowed time as the gasket will fail.
They both advise that I should not waste any more time as prevention will be a lot cheaper that waiting for a failure.
Your thoughts would be appreciated
If the gasket fails your coolant alarm will go off or you'll spot a problem.
Fixing it wont be any more expensive than changing it now. If you feel happier changing it then that's your choice.
With a low coolant alarm, you will be warned well before any head damage.
These heads don't take well to skimming anyway as they are case hardened Alloy and excessive skimming removes the hard 'shell'. Skimming should NOT be carried out as a matter of course,as you would with a cast iron head.
I have Had two head gasket failures( I have done 150'000 miles), both with the coolant alarm fitted and I still have the original head. Unskimmed, just cleaned up and refitted by MGROVERSOLUTIONS.com
Within the last year, I have seen 2 early cars have head gasket failure when the mileage approached 60,000 miles. Also, shortly after I bought my F I remember reading on one of these forums that a large percentage of K-series engines suffered head gasket failure around about 60,000 miles.
I do agree with the guys that if you do have a low coolant alarm fitted and if you monitor the coolant level in the expansion tank, there is no need to replace the head gasket until you see/hear signs of failure (dropping coolant level).
[size=10pt]Mark[/size]
95 MGF
- sworkscooper
John
The failure of one was attributed to a cheap water pump leaking which was fitted at the same time as the cam belt was done approx. 45k.
I'm of the opinion that I knew at some point the gaskets were going to go; so I wasn't surprised when they did, unfortunately both cars going at the same time was not in the plan.
With the cars I do tend to wait for a fault to happen before the fix takes place, mainly down to time constraints; otherwise I would be out there tinkering, or messing about as my wife calls it,....bless her. However in our mechanical and electrical workshops we are always carrying out what is called PPM,s, which stands for "planned preventative maintenance" (changing belts, bearings etc before they fail).
Almost everything has a life cycle; so at the end of that life cycle that particular piece of equipment gets replaced no matter what condition it is in as the cost has been budgeted and accounted for. Luckily I had money set aside for the inevitable HGF; therefore I think the jist of this reply is for the piece of mind alone, and the mileage is above 50k, still with the original gasket then plan on getting it done while you can still control it.....wish I had done! :woowoo: I love these modals!
- mgtfbluestreak
