Volumetric Sensor for MGF
I have a problem with my MGF car alarm which frequently sounds when the ambient temperature is high - like now (spanish summer time)!!
I believe that the volumetric sensor is faulty.
I note that when replacing the microwave sensor on MGFs prior to VIN WD030082 (1998), a link harness YMQ103410 must also be fitted.
My MGF VIN is SARRDWBTCAD022706 (1997 MODEL)
I opened the T-bar from my MGF and removed the fitted volumetric sensor. No obvious link harness.
It is a genuine ROVER part (number 5811-002-9710-00020) and has a blue multi-pin connection. See attached photos.
Frequency band: 2.446 - 2.454 GHz.
It was manufactured by GEC Plessey Semiconductors in the UK.
Does anybody know where I can source a replacement sensor?
Last Edit:5 years 3 months ago
by MGhugh
Last edit: 5 years 3 months ago by David Aiketgate. Reason: Inserted photo
- SundanceUK
Try MGFnTFbitz - a google search will find them. They stock everything F and TF and will post worldwide.
Sundance
Sundance
by SundanceUK
The following user(s) said Thank You: MGhugh
Hi and welcome to the forum.
Let us know how you getting on resolving your problem.
James
James
by talkingcars
:welcome2:
You can isolate the volumetric sensor by locking the car with the key rather than the fob.
Thanks I will give them a try!
by MGhugh
Thanks - but I prefer not to wear out my door lock barrel. Now that I have disconnected the sensor, I can use the fob again!
by MGhugh
Time to create page: 0.576 seconds
