Throttle hesitation and overrun.
- BruceTF135
Is this normal? I have been recommended to clean the throttle body. Is this straightforward? Is there a howto? I cannot find anything here.
I should add that I have changed the throttle cable (OE from Rimmers) to no effect.
As always, advice appreciated.
- SundanceUK
If that does not work, then its time to look at the idle air control valve, they have been known to stick, again the how to section should have info on this.
I keep a spare second hand one in my spares box just in case.
Sundance
- BruceTF135
I'll have a look at the IACV, when I get a chance. I have a feeling it's a completely sealed unit; is that right?
Replied by David Aiketgate on topic Throttle hesitation and overrun.
Posted 5 years 2 months ago #191423It would be worth disconnecting the throttle cable and operating manually to see if it is definitely the throttle body.
Replied by talkingcars on topic Throttle hesitation and overrun.
Posted 5 years 2 months ago #191470I have seen various suggestions but the correct method is
1) switch ignition to position II but do not start the engine
2) firmly and fully press the gas peddle to the floor and release 5 times in 30 seconds
be slow and deliberate, do not jab.
3) wait 30 seconds
4) start the engine
- BruceTF135
Entering my EKA code certainly makes plenty of noise but that is another story!
Posted 5 years 2 months ago #191486BruceTF135 wrote: …….It's a shame that when the (correct) procedure has been followed there is no indication that the recalibration is successfully completed. A beep or something...….
If you were standing at the back of the car you would hear the stepper motor moving in and out for a few seconds.
- BruceTF135
Bob wrote: Check the throttle cable is running free and not slack by the throttle body. Also the peddle isn't sticking.
Thanks for the input. But the throttle cable is new, runs freely and the pedal doesn't stick
- BruceTF135
Thanks, TC. That is very helpful. I'll check that.
- BruceTF135
Video here on YouTube
I've tried to insert the video without success. Is there a 'how to insert a video' somewhere?
AFAIK there isn't a "How To" on inserting a video but it looks like you nearly got it right. I've edited your post to show the video in the web page. All I did was copy your You Tube link, hovered on the film strip icon in the ribbon, selected video and then pasted the link to the clip.
Robin
