Throttle hesitation and overrun.
- BruceTF135
If I operate the accelerator or twist the throttle butterfly, the revs increase, obviously. But when I release, there is a very noticeable pause before the revs decrease again. I've replaced the throttle cable and tried disconnecting it from the throttle body, just in case. I have now thoroughly cleaned out the throttle body and fitted a new idle air control valve (IACV). I have reset the TPS. The air and fuel filters were replaced about 1yr ago (1000 miles). But none of this has made any difference.
Is this normal for a TF135? It doesn't seem right to me.
Does anyone have any ideas? Would a remap help?
- SundanceUK
Sundance
Have you tried contacting Jon Norris? He has hepled me before. send him a link to this thread he may have a few more ideas on how to sort your problem Bruce.
Replied by David Aiketgate on topic Throttle hesitation and overrun.
Posted 4 years 7 months ago #192866Should be 875 ish and steady. Does the idle speed wander?
- BruceTF135
SundanceUK wrote: I would have a look at the fuel canister next. This absorbs excess fuel and cycles it back into the system, maybe it is not working correctly and you are over fueling the injectors....then maybe the injectors themselves may be an issue.
Sundance
Fuel canister? That's a new one on me! Is it the black plastic thing you can see from the boot, close to the throttle body with a bunch of pipes coming out of it? I've always wondered what that is and what it does. Can it be tested/serviced?
Can the injectors be serviced in any way? This is the first fuel-injected car I've ever worked on!
- BruceTF135
David Aiketgate wrote: What is the idle speed sitting at when the engine is hot?
Thanks for the reply, David.
The idle speed is 875 ish - always has been. It's rock steady. When cold, the engine starts at about 1500rpm but immediately drops to about 1100. Then it slowly drops to 875 as it warms up a bit.
Should I assume that this 'overrun' is not correct? The car drives fine otherwise.
Posted 4 years 7 months ago #192878Difficult to tell on the video if that is unusual overrun or just normal.
- SundanceUK
The fuel injectors can be removed and cleaned, not done them on a TF but I have had them out on my KV6 engined ZTT. Just make sure you buy a seal or O Ring kit for the injectors and fuel rail before starting, as the seals would be best replaced when refitting, and just in case you damage any when taking the injectors out. I think they can be cleaned carefully, but to be honest for what they cost, if I was removing them, I would fit new and be done with it.
Good luck with the fault finding.
Sundance
Replied by talkingcars on topic Throttle hesitation and overrun.
Posted 4 years 7 months ago #192885SundanceUK wrote: …..the fuel canister next......
Charcoal canister,,,,,?
While gear changing, MEMS keeps revs up to improve faster and smoother gear changing. Maybe that is your problem and must you to get used on this.
Just some idea but maybe helpfull.
Schrokke
- SundanceUK
- Larry Nicoll
- Novice MGer
Replied by Larry Nicoll on topic Throttle hesitation and overrun.
Posted 4 years 7 months ago #192898Please Log in or Create an account to join the conversation.
