Camshaft oil leak
Camshaft oil leak was created by ianperry34
Posted 5 years 1 month ago #191671
Hello all, 2004 MG TF160. I have an oil leak from the exhaust n/s seal.
I understand spécial remove and insert tools are required. Question 1, is it a simple job or are there complications to look out for? and 2, where best to get the tools to do the job?
TIA
Ian
Replied by David Aiketgate on topic Camshaft oil leak
Posted 5 years 1 month ago #191678
Have read of this. https://www.the-t-bar.com/forum/9-mgf-tf-pitstop/94958-rear-camshaft-cover-seal#175188
The following user(s) said Thank You: ianperry34
Replied by mowog73 on topic Camshaft oil leak
Posted 5 years 1 month ago #191694
In the linked thread that David has provided it talks about a video on changing the camshaft seals in the how to section by mgfbluestreak but I can't find this video. Does this video still exist, or am I just missing it in the list of videos?
[size=10pt]Mark[/size]
95 MGF
by mowog73
Posted 5 years 1 month ago #191700
Mark, it's just a quick section of a longer video at 20:50.
Last Edit:5 years 1 month ago by David Aiketgate
Last edit: 5 years 1 month ago by David Aiketgate.
Posted 5 years 1 month ago #191702
Thanks David for that tip about where to find to portion on the video about camshaft seals.
I must say, I was hoping that the video was showing someone fitting new seals in situ. My wife's F needs new front and rear seals. The rears can be fitted with the cylinder head on the engine but I can't quite figure out how to install new front seals with removing the cylinder head.
95 MGF
by mowog73
Time to create page: 0.538 seconds
