Winter Restoration Project
Winter Restoration Project was created by Postman87
Posted 5 years 1 month ago #191704
After removing the front subframe on Tuesday I've spend the last few days avoiding the rain by moving into my untidy garage and an MOT for my daily car plus a strip down of the subframe. I'm nearly there but having trouble removing the Front Upper Arm. Any advice would be gratefully received.
Last Edit:5 years 1 month ago by Postman87
Last edit: 5 years 1 month ago by Postman87.
Replied by talkingcars on topic Winter Restoration Project
Posted 5 years 1 month ago #191706
Not sure on the top arm but it looks like you'll be busy.
Replied by Postman87 on topic Winter Restoration Project
Posted 5 years 1 month ago #191709
You could be right, however it looks worse than is. Doesn't seem to be any serious rust on the subframe. I'll know once i take the rust off. I'm in no hurry as i have no plans to have it on the road until next summer. Have to be honest getting the subframe off was easier than i expected thanks to CJJ's How To. Won't say how many bolts snapped but I'll be going through a few drills to remove them :yesnod: Looks like i can refurbish most of the parts with a combination of sanding and blasting and a bit of painting.
Replied by VX54NEW on topic Winter Restoration Project
Posted 5 years 1 month ago #191714
Hi
To remove the upper suspension arm first remove the locking plate held in by 2 small nuts and bolts the remove the nuts from the shaft ends and the bar should push out allowing the arm to pull out of the recess.
Regards Kevin.
by VX54NEW
The following user(s) said Thank You: mowog73, Postman87
Posted 5 years 1 month ago #191718
Thanks Kevin
Didn't see those little bolts hiding down there.
Posted 5 years 1 month ago #191720
Strip down now complete. I now have a pile of rust parts which I'll go through at my leisure over the next few months.
Posted 5 years 1 month ago #191721
Not much left of the front subframe mounts
Posted 5 years 1 month ago #191725
Had a few hours spare this afternoon so took the opportunity to degrease the sub-frame and start taking the rust off. So far it seems that it's all surface rust as it's pretty sold underneath.
The following user(s) said Thank You: David Aiketgate, sworkscooper
Posted 5 years 4 weeks ago #191779
Had a few spare hours this morning so it was out with the grinder and a sanding attatchment. Brace bars and Anti roll almost rust free. A little tidy up in the awkward parts and it ready for primer, hopefully sometime this week.
Time to create page: 0.714 seconds
