TF cam belt change questions
I'm new to this forum, having bought my 2004 135 TF in August. It came with a service history, however studying the paperwork I don't think the cam belt has been changed since 2008. It's done 53k miles so probably very overdue for a change. I've decided to do the job myself and having studied the various threads on the subject i cant find answers to the following
1. What is the best quality belt kit available, Gates?
2. I can't see that any of the belt kits come with a patchlok bolt for the tensioner. Can the old one be re-use with some threadlock?
3. I don't want to completely drain the cooling system this time, approx how much needs to be drained in order to change the water pump?
Grateful for any help
I can't answer your questions but personally I would do a coolant flush while you have the car apart and fill with freash OAT.
James
- BruceTF135
[size=10pt]Mark[/size]
95 MGF
- mgtfbluestreak
I was quoted £340 by my local garage which seemed a bit steep. I've just ordered a kit and will make a start on the job next weekend. And yes, whilst I've got the car apart I'll do a proper job on the cooling system!
95 MGF
- BruceTF135
rosey wrote: Yes I have one of those. However the price of the flywheel locking tool put me off getting one so for the crankshaft pulley bolt i thought i would try putting it in gear with someone stamping on the brakes, if that fails will try a flat bladed screwdriver in the ring gear.
It's probably not the recommended technique but a beefy flat-bladed screwdriver in the starter ring is the way my mechanic did it on my car. Up on the 4-poster with the screwdriver in one hand and a breaker bar to undo the pulley bolt in the other. Done in seconds.
mowog73 wrote: I have never had luck with someone standing on the brake pedal. I ended up breaking down and buying the locking tool.
What happened, did the car just move?
- terreneuve
The bigger issue is when torqueing up the pulley bolt after the job is done, if not torqued properly the bolt can back off, you don't want that to happen!
