TF cam belt change questions
terreneuve wrote:
rosey wrote:
mowog73 wrote: I have never had luck with someone standing on the brake pedal. I ended up breaking down and buying the locking tool.
What happened, did the car just move?
The bigger issue is when torqueing up the pulley bolt after the job is done, if not torqued properly the bolt can back off, you don't want that to happen!
Would some threadlock help?
- terreneuve
It doesn't say to use threadlock in the workshop manual but personally I can not see it being a problem just be careful which threadlock you use.
Went out to the garage tonight and managed to undo the crankshaft pulley bolt. I jammed a bit of angle iron in the flywheel ring gear and with a bit of piping over my longest breaker bar, hey presto!
The rubber bonding piece on the rear face of the pulley is showing some minor splitting, do I need to be concerned about this?
Many thanks
Jon
- mgtfbluestreak
Cheers
Replied by David Aiketgate on topic TF cam belt change questions
Posted 4 years 11 months ago #192020A garage would use a gas torch.
- mgtfbluestreak
Replied by mgtfbluestreak on topic TF cam belt change questions
Posted 4 years 11 months ago #192043Please Log in or Create an account to join the conversation.
- SundanceUK
rosey wrote: Hmm those 2 engine mounting bolts are turning out to be a pig. I've tried loads of plus gas and heat from a hot air stripper. One thought though is a bit air stripper hot enough or do it need to get an actual flame onto the casting/bolts?
Cheers
I had this issue with mine when I had my cambelt last done. In the end I had to replace the arm that the bolts screw on to. The guys doing the cambelt change were fearful that the bolts would sheer off, they were that tight. Good job as the rubber engine mount was also knackered and they would not have spotted that if they had not replaced the arm. I undo and re-torque the bolts up again every year when I do a service on my car now.
Sundance
- SundanceUK
Sundance
- mgtfbluestreak
Posted 4 years 11 months ago #192048Please Log in or Create an account to join the conversation.
