TF cam belt change questions
The first time I tried to remove those bolts I was able to undo one but there other wouldn't budge. I broke a socket trying to undo it. I also tried to unbolt the mount from the engine block but none of the bolts would budge. I ended up cutting the head off the seized bolt and pounding the bottom of the mount from below until it move upwards enough to get a puller under the mount and pulled it off. I them removed the bolt by welding a nut to it and the heat of the welding heated the bolt enough to allow me to remove the bolt. It took me a month of free time to get the mount off and the bolt out.
The bolt was covered in white powder (aluminium oxide I believe). Yeah for dissimilar metals in a damp environment. I now use antiseize on every bolt going into an aluminium alloy part.
[size=10pt]Mark[/size]
95 MGF
I'm doing this job very part time so has taken me weeks already. I'm hoping the actual belt change will turn out to be the easy bit.
Tonight I undid the nut on the outer tie bar bolt but the bolt refused to slide out, even with encouragement from a hammer.
Does anyone know if jacking the engine up now would help free this bolt?
Thanks
95 MGF
If this fails is the only option removal of the whole buttress? If so can this be done without removing the trailing arm?
If I disconnect the 4 x 13mm bolts holding the mount to the engine, is there room for the whole assembly to come out above, or below?
Thanks
95 MGF
Managed to spend more time on this today. I took off the trailing arm then undid the 4 buttress to subframe bolts. Then i undid the 4 x 13mm bolts holding the engine mount to engine. I noticed that the compliance bush had seen better days. I tried to wriggle this out but there doesn't seem to be enough clearance between the subframe and body. Is there a way of removing it?
As for the mounting it looks like the hydramount will need to come out first. As one of the bolts is solid and so is the right hand bolt through the link arm, preventing me from swinging it up, does anyone have any other ideas. I suppose I could saw through the link arm to try and get a socket on the second hydramount bolt.
Grateful for any ideas
Thanks
Replied by David Aiketgate on topic TF cam belt change questions
Posted 4 years 9 months ago #192476David
The problem is that in my haste to get the hydramount off at the weekend I cut the hoop from around the bolt that was seized. I stupidly cut into the hydramount flange.
What are peoples' opinions please about whether I can reuse it? Of course it's only now I know I didn't need to resort to such drastic measures :bat:
*disclaimer - I am not a trained mechanic so this is my personal opinion.
Posted 4 years 9 months ago #192511David
