Misfire on start-up
- [email protected]
- Novice MGer
The issue only appears to happen when I've either washed the car (large amounts of water through the boot engine vents) or when it's lashed with rain, as it has done over the past month. I've checked the coolant expansion bottle and there does appear to be a very slight drop in coolant level, but we're talking a few MM's. There's no sign of any oil in coolant or visa-versa. I have had a replacement engine fitted as a result of HGF. I have read that this problem can be down to a leaking inlet manifold and I'm wondering if this could be the case as a result of the gasket not being fitted correctly when I had the new engine fitted. Any ideas on this topic would be welcome.
This certainly sounds like a typical inlet manifold water leak problem. The symptoms of rough start up and steam from the exhaust point that way. This happens more with the plastic inlet manifold than the later/ better alloy manifold but it is not unknown for a later manifold to give problems. You might also be able to see coolant stains below the inlet manifold.
An easy way to tell is to take out the spark plugs. No.4 (normally) will be unusually clean.
Of course there is the other way for water to enter the cylinders, i.e. HGF
- [email protected]
- Novice MGer
I had problems with very rough running and difficulty starting and it turned out to be bad connection to the sensor (a bit of WD40 seems to have sorted it out). Maybe damp is getting to it..
- [email protected]
- Novice MGer
- SundanceUK
May treat myself to a couple of new spares next year.
Sundance
- mgtfbluestreak
Which diagnostic kit did you use?
And was this on the 135 in your signature?
- mgtfbluestreak
Below are the 2 obd results
Pics in the wrong order but clearly you can see the different readings has the coil packs are changed over...a very quick diagnostic in minutes..and the fault code is clearly seen...afterwards the ECU was cleared of fault history
- SundanceUK
Sundance
- [email protected]
- Novice MGer
