Radiator Bleed Screw Leaking
Radiator Bleed Screw Leaking was created by Pusb
Posted 5 years 3 weeks ago #192050
Hi,
I noticed the radiator bleed screw was weeping slightly a few weeks ago, so I ordered a new screw. However now that I've received it I've noticed it looks nothing like my existing one. Was there more than one kind used? Its a 2001 model.
The existing one seems to be much bigger
This is the replacement I bought
by Pusb
Replied by adamelphick on topic Re:Radiator Bleed Screw Leaking
Posted 5 years 3 weeks ago #192051
As long as the thread is the same you'll be fine. The hex nut is easier as the screwdriver type losses it's slots over time as you can tell from your old one. Once they've rounded it's a bugger to get off!
Sent from my CLT-L29 using Tapatalk
Replied by talkingcars on topic Re:Radiator Bleed Screw Leaking
Posted 5 years 3 weeks ago #192055
The standard rad only had one size of screw but after market rads may be different. The only way to tell if it will fit to is try it.
Replied by SundanceUK on topic Re:Radiator Bleed Screw Leaking
Posted 5 years 3 weeks ago #192063
I think the later ones were of the Hex variety, both my 2004 cars had the hex bleed screw fitted. This is a good memory jolt by the way, its a spare I do not carry in my little box of essential bits, so will make sure I get hold of one!
Sundance
Posted 5 years 3 weeks ago #192064
As an aside, I've got this type which fitted both my original 2003 rad and my alloy one.
Replied by mgtfbluestreak on topic Re:Radiator Bleed Screw Leaking
Posted 5 years 3 weeks ago #192069
I ditched the standard plastic one for a alloy Mike satur version...better quality than the naff plastic ones and looks good
Last Edit:5 years 3 weeks ago by mgtfbluestreak
Last edit: 5 years 3 weeks ago by mgtfbluestreak.
Posted 5 years 3 weeks ago #192072
mgtfbluestreak wrote: I ditched the standard plastic one for a alloy Mike satur version...better quality than the naff plastic ones and looks good
Yeah, shiny shiny Mr. Bluestreak! will treat myself to one!
Sundance
Replied by David Aiketgate on topic Re:Radiator Bleed Screw Leaking
Posted 5 years 3 weeks ago #192076
The Satur version is threaded for the oem radiator, as I found to my cost when I tried to fit it to my aftermarket rad...:nonod: :slapme:
Posted 5 years 3 weeks ago #192085
Yes I bought the aftermarket radiator and then bought the satur bleed nipple...it didn't fit...hee so I engineered it to fit..😁...if I remember right the satur bleed valve being bigger than the hole in the after market rad..so I would of drilled the hole larger tapped a thread and fitted a insert to the exact thread pitch and size so the satur nipple wasn't wasted.and fitted correctly..here's a pic of the new rad going in with satur valve fitted..
The following user(s) said Thank You: Raccoon
Time to create page: 0.537 seconds
