Brakes
Brakes was created by cjj
Posted 14 years 9 months ago #9691
Well, I have just won a little modification that I am going to try.
I might have to do it round Phils house as he s now the expert on brakes.
I have just won a 280mm disc and conversion set for the rear brakes for £132.
Is it a bargain?
Well, VHS do a 266mm brake conversion kit for around £395.50.
So, if they work as planned then they are slightly better and cost £263.50 less.
They allow you to keep your current callipers while increasing braking torque and thermal dissipation. This does away with problems involving the hanbrake mechanism etc that you may get if you change the callipers.
I will try changing them first with no change to the front brakes or the pads and see how it compares. I will then be fitting my new bargain EBC drilled and grooved discs and maybe greenstuff pads all round and see how that does.
Hopefully I will be able to give you some sort of advice on whether it improves braking or not.
It is also designed to fit under 15" wheels as well.
These are the discs and spacers. You also get spigot rings and stainless bolts etc.
Not sure that is mounted right to be honest, as the spacer moves out a bit so I would have thought you mount it on the inside of the spacer bracket.
This is what they look like behind the 11 spokes.
And behind the 15" wheels.
You have to admit, at the very least, they fill the wheels out better and improve the looks drastically. Lets just hope they work.
Replied by phil-hex on topic Brakes
Posted 14 years 9 months ago #9706
Clive mate,
you're more then welcome bring them to my house and I'll happily fix them onto my car :hehe:
definitely worth a try at that price :yesnod:
:notworthy::notworthy::notworthy: Sir Clive the ebay brake bargain king :notworthy::notworthy::notworthy:
Replied by cjj on topic Brakes
Posted 14 years 9 months ago #9707
Ha. Just need some bargain greenstuff pads now. :whistle:
Replied by David Aiketgate on topic Brakes
Posted 14 years 9 months ago #9712
Interesting!:yesnod:
Looking at the kit, it appears that would also work for the front. :dunno: And keep the rears standard?
What happens when you need to replace the discs? What are they from originally?:dunno:
Posted 14 years 9 months ago #9715
I did ask that and the seller said that they are OEM discs machined to fit. He said he can supply the discs. It would also be possible to buy some 280mm discs and have them machined to suit, so not really a major problem.
Replied by rough luck on topic Brakes
Posted 14 years 9 months ago #9728
It would be really interesting to know the measurements of that spacer block, I could feel a garden shed nock out a dozen moment coming....lol
Well ok a milling moment, but still in the shed...lol I'm sure 280mm discs are standard on some rover/MG
As for the pic of the spacer, I remember a guy putting that up on .Org when he was mocking it up.......I remember because everyone was saying its mounted wrong, but he insisted it would work like that....logic still says if you put it on the other way the disc would be in more of its original position
Pleaseeeeeeeee measure the block....lolol I'll do them at cost.....lol
Replied by reaper on topic Brakes
Posted 14 years 9 months ago #9733
CJJ;9691 wrote: Not sure that is mounted right to be honest, as the spacer moves out a bit so I would have thought you mount it on the inside of the spacer bracket.
I would agree, but maybe the different disk resolves this?
I've always wondered about this mod; as the braking force doesnt change does it? same caliper and carrier so the same PSI on the disk, so i suppose only the heat loss and looks? Does that sound right or am i missing something?
Great pics as ever CJJ. I have to say i do wish MGR had filled the rear out a bit.
[SIGPIC][/SIGPIC]
by reaper
Replied by quicksilver on topic Brakes
Posted 14 years 9 months ago #9738
Reaper;9733 wrote: I would agree, but maybe the different disk resolves this?
the braking force is proportional to the force from the caliper and the leverage from the disc, so larger disc -more leverage better braking +better heat dispersion.Limits to braking force are more from tyre adhesion then anything else once you hace sufficient leverage.
Chris
Posted 14 years 9 months ago #9746
Rough Luck;9728 wrote: It would be really interesting to know the measurements of that spacer block, I could feel a garden shed nock out a dozen moment coming....lol
Oh yes, I'm up for two of them:yesnod:
Posted 14 years 9 months ago #9747
Perhaps the new disc has a shallower hub drum, and the moved position of the caliper is to compensate for that?
Did MG Maestros not have 280mm discs? Don't know, just wondering, it was/is a big car:dunno:
Posted 14 years 9 months ago #9752
If someone has the time to search the .org threads I think he actually mentions what the discs are from......dam this photographic memory.....shame its only on time laps an misses the odd frame
Replied by gotenks1321 on topic Brakes
Posted 14 years 9 months ago #9753
David Aiketgate;9746 wrote: Oh yes, I'm up for two of them:yesnod:
Agreed :yesnod: Wouldn't mind some bigger breaks to fit under the 16" square spokes at the fronts too without spending £400+ :frown:
Time to create page: 0.568 seconds
