Engine Management Light
Replied by talkingcars on topic Re:Re:Engine Management Light
Posted 4 years 11 months ago #192124
A sold engine management light (EML) shows that the ECU has seen a situation likely to give rise to high emissions. A flashing EML shows that the ECU has seen a situation that can cause damage, probably to the cat.
On the Rovers and MGs a solid EML will clear after 5 complete ignition cycles after the fault has gone.
A cheap OBD2 reader will clear a EML and read generic codes on compliant cars which is any with a MEMS 3 ECU. It won't access anything beyond the OBD2 area. A www.pscan.uk will read earlier cars and will read other areas on all car.
The following user(s) said Thank You: davidgv1
Replied by Norm on topic Re:Re:Engine Management Light
Posted 4 years 11 months ago #192127
Thanks very much. My light is solid, but i havn't used it since anyway. Pardon my ignorance but mine is a 2002 TF160. Is that MEMS3?
Norm
by Norm
Replied by David Aiketgate on topic Re:Re:Engine Management Light
Posted 4 years 11 months ago #192128
Yep. Mems3
Posted 4 years 11 months ago #192142
Thanks David
by Norm
Replied by Norm on topic Engine Management Light
Posted 4 years 10 months ago #192195
I decided to take the MG to my son's at Winchester this christmas anyway. I started it up and the EML went out, but 5 seconds later it came on again. Anyway, i drove to a friends to deliver a present and then when i set off again the light went out and stayed out! 350 miles later it remains off so i'm assuming i now have the world's only self fixing TF.
Hope every one had a good christmas
Norm
by Norm
Replied by adamelphick on topic Re:Engine Management Light
Posted 4 years 10 months ago #192198
Could have been an O2 sensor needing a good run to clear it off....
My ZS has one that is borderline. If I use the car a lot it's fine, less and it throws a fit after a week or so of short runs.
Sent from my CLT-L29 using Tapatalk
Last Edit:4 years 10 months ago by adamelphick
Last edit: 4 years 10 months ago by adamelphick.
The following user(s) said Thank You: Norm
Replied by talkingcars on topic Engine Management Light
Posted 4 years 10 months ago #192205
Norm wrote: ……...so i'm assuming i now have the world's only self fixing TF.
The EML stops illuminating after 5 complete ignition cycles after the perceived fault was last noted.
A perceived fault is one that would cause the emisions to be out of spec.
Posted 4 years 10 months ago #192206
but I already said that.
Posted 4 years 10 months ago #192213
Sorry talking cars; i wasn't ignoring what you said before; but surely if the perceived fault was still there it would have just set the light off again, on the sixth start? or is that not how it works? As you may have realised this is slightly outside my area of expertise. Although to be fair after 63 years i'm still yet to find "my area of expertise". I hope it comes soon or i won't have long to use it!
by Norm
Posted 4 years 10 months ago #192215
Don't worry, I realised after I posted yesterday I had already posted.
Norm wrote: ......but surely if the perceived fault was still there it would have just set the light off again, on the sixth start?....
If the fault is still there the light won't go out, it only goes out 5 cycles AFTER the fault has gone, or if cleared with a OBD reader.
Posted 4 years 10 months ago #192233
Thanks, so the fault must have gone....excellent.
by Norm
