Bolt on rear suspension broke
Hi all, my oh went over a large pothole today and the impact has broke a bolt on the rear n/s part of the car, which I can only presume is the bottom bolt mounting for the shock absorber, a mechanic put it on the ramps and had a quick look and said it's taken out the drive shaft gaiter as well, can anyone help on this? The problem I have is that the car's in Burford near Tenbury Wells, which is about 35 miles from where I live, and it's not driveable. Does anyone know someone in that area who would be able to either repair it or bring the car back home for me?
by jelly
Which model?
by talkingcars
- sworkscooper
Ouch ! Tis the season of pot holes ! Sorry Jelly can't help you as I'm a Yorkshire lad . Hope you get it recovered and sorted soon . Try and have good Christmas .
John
John
by sworkscooper
HI jelly,
the most likely on the rear suspension is one of the drop links -these in a way are meant to be sacrificial so as to avoid more serious damage
Mike
Mike
by g4wam
- adamelphick
Replied by adamelphick on topic Re:Bolt on rear suspension broke
Posted 4 years 11 months ago #192170
Any chance you could get a bolt, jack the car a bit and get it back in? Even a temporary bolt would do for a slow journey home. The gator shouldn't matter for a quick trip.
The lower shock bolts are a known weak point as they are ageing and under quite a bit of stress.
Sent from my CLT-L29 using Tapatalk
Last Edit:4 years 11 months ago
by adamelphick
Last edit: 4 years 11 months ago by adamelphick.
Hi Mike, thanks for that, trying to get some info. together, it's a bit difficult because I haven't seen it myself yet.
by jelly
not really sure at this stage, only got what oh told me to go on and the mechanic who only had a very quick look at it, could really do with having a look myself
by jelly
Remember to get B/D ins. next year!
Hope you get it solved.
by Forrester
Have had a glance at the car now, it is the ns shock absorber bottom bolt that has snapped off, ordered another one
by jelly
- adamelphick
Posted 4 years 10 months ago #192189
Thought it would be that one. There is a bit of tolerance in the fit and they wear and get brittle. Glad it's something simple at least.
by adamelphick
Time to create page: 0.900 seconds
