Bolt on rear suspension broke
Next thing is what are the chances of removing the other half on side of road ? Trying to find out if we have breakdown recovery we are insured with RAC but site down.
by jelly
- adamelphick
Replied by adamelphick on topic Re:Bolt on rear suspension broke
Posted 4 years 10 months ago #192191
It's just a push through bolt so take a long skinny bolt and a hammer/mallet, then bash it back through.
You'll need to Jack the car up to drop the wheel/suspension so you can get the new one in. You might need to push down on the wheel (or hub if you remove the wheel) to line up the holes.
Good luck!
Sent from my CLT-L29 using Tapatalk
Good luck!
by adamelphick
Dam ordered from Rimmers but need nuts then as well?
by jelly
- adamelphick
Posted 4 years 10 months ago #192193
Bugger, doesn't it come as nut and bolt combo?
There are two types as well. The original and an 'updated' version from the Chinese cars. Not sure which is best to be honest.
by adamelphick
Not that I can see on rimmers. Thanks everybody for the help.
by jelly
Just an update on this just got off the phone to rimmers and they confirmed the TF doesn't have a nut on the rear shock absorber bottom mounting.
by jelly
- adamelphick
Posted 4 years 10 months ago #192214
Oh yea they bolt into the arm itself. I should have remembered that seeing as I changed mine for Bilsteins.
DOH 😜
DOH 😜
by adamelphick
That makes a easy get you home fix potentially a nightmare anybody got a guide price to fix this ? Have now ordered the bolts and gaiters but they are going to come to my home address. Can get it recovered this week if I arrange soon?
by jelly
- adamelphick
Posted 4 years 10 months ago #192217
If the bolt snapped right where it bolts in to the top arm you might not be able to get the broken bit out very easily. It could be a replacement top arm as well.
Hopefully it has snapped with a bit sticking out to get hold of. 🤞
by adamelphick
Yes that's what I was thinking this is going to be an expensive bolt think it is going to be a recovery truck job trouble is the time of year and need this car at the moment and think the other halve might be losing confidence in it too
by jelly
- adamelphick
Posted 4 years 10 months ago #192219
That bolt is known weakness, and if you think it gets a lot of stress over its life.
The to arms are not expensive even if you need one. It's just fitting it, which again isn't that difficult. It's one long bolt at the subframe end, and the to ball joint nut. Not much else.
It's a pity it happened at this time of year as it makes it less pleasant to do.
by adamelphick
- SundanceUK
Replied by SundanceUK on topic Re:Bolt on rear suspension broke
Posted 4 years 10 months ago #192220
When I replaced my shock absorbers a couple of years ago, I remember looking into the Chinese bolts and the OEM Rover ones, I think I ended up fitting the standard OEM bolt, but what I did do was to put a nut on the protruding thread of the bolt after it was tightened up. This locked nutted the bolt to the suspension arm and mainly it was to help keep the thread of the bolt protected so if I wanted to remove the bolt in the future, the thread should be nice and clean and healthy once I took the nut off again.
Sundance
Sundance
Last Edit:4 years 10 months ago
by SundanceUK
Last edit: 4 years 10 months ago by SundanceUK.
The following user(s) said Thank You: talkingcars, Raccoon
Time to create page: 0.514 seconds
