Is the TF gear change shorter?
The TF has a shorter lower gear cable than the F, does this give it a quicker gear change?
Many thanks
James
Many thanks
James
by talkingcars
Replied by David Aiketgate on topic Is the TF gear change shorter?
Posted 4 years 10 months ago #192325
Yep. Except I believe it's actually the mk2F where they first introduced the different gear cable arrangement, so only the mk1 F has the longer sloppier gearchange.
Thanks David.
The components are listed for either MGF or TF so I'm not sure.
As I am having to change the short cable on my mk1 and it transpires the replacement I had in the shed is one from a TF.
I was contemplating getting the correct cable as it is the quickest solution but I have a TF gearbox in the garage so might swap the components over, or should I get a new bell crank from either Mike Satur or MGFmania, oh the dilemmas.
by talkingcars
It's not just the cable and bell crank, the actual gear lever is shorter too.
The mk1 F is 17cms long, the pre-production TF is 15 cms.
by talkingcars
Time to create page: 0.468 seconds
