Tyre time again
Hi,
Sorry to be a tyre bore, but my tyre supplier tells me that Falken ZE914's have been phased out, being replaced by ZE310's. Roxy's on 16" rims so she needs 215 40 R16's. Has anyone experience of these spec tyres in that size please?
I'm loath to try Toyo's again, as last time I did Roxy was so unsettled/dangerous, I took them off after a couple of hundred miles. As such therefore, I'm in a bit of a quandary as to what tyres to go with now.
All advice gratefully accepted.
Thanks,
Winko
Thanks,
Winko
by Winko
Replied by Winko on topic Tyre time again - updated info - answered my own question.
Posted 4 years 10 months ago #192329
I've found this on the MGF Forum from last year:
"Roger Parker wrote:
Rob,
A heads up that Falken may soon be reducing production of their ZE914 tyre that is one of the approved tyres for TF and they are starting to introduce the replacement which is the ZE310. I have been liaising with Andy Kitson for some months and he put a business plan through to SMTC and MG Motor for additional tyre testing to verify the suitability of the ZE310 for the MG Motor TF (and cascading down to MG Rover TF and MGF).
This was declined but having got Falken on board with tyre supply, Andy was able to complete a road test programme to the same level as was applied to previous MG tyre testing and has been able to conclude that the new ZE310 Ecorun is suitable as a replacement tyre for TF. He also extended the testing with the tyre pressures that are applicable for the MGF although using a TF, and this concluded that the tyre remained suitable. I have a fuller report in the offing for probably August EMG and I can forward you a copy of that closer to the time, but in the meantime knowing that the new ZE310 is acceptable in the usual full set of four and at recommended tyre pressures will be a comfort to many.
Rog"
On the basis of this I've ordered ZE310's for Roxy's rears, leaving the 'proper' Toyos on the front. I'll let you know how she behaves with that mix...
Winko
Rob,
Rog"
Winko
by Winko
- BruceTF135
Replied by BruceTF135 on topic Tyre time again - updated info - answered my own question.
Posted 4 years 10 months ago #192330
I read somewhere (it might have been here) that the Falken ZE310 had been recommended by the MGOC. I am not a member so I cannot confirm. Also, I'm not sure whether that was for the MGF or MG TF or both. Sorry, this probably doesn't help at all, does it!
by BruceTF135
Posted 4 years 10 months ago #192331
Thanks Bruce - every bit of information and advice is greatly appreciated.
by Winko
Time to create page: 0.511 seconds
