Engine Start after a Break
Engine Start after a Break was created by Martinm760
Posted 4 years 9 months ago #192487
Hi. My lovely TF 160 has been laid up, sorned, in a warm dry garage for nearly 2 years now as I work away from home. I’m due home soon for a short brake and thought I’d start it up for a bit of an airing. so, any advice before starting her up again?
Replied by talkingcars on topic Engine Start after a Break
Posted 4 years 9 months ago #192490
I'd probably disconnect the coil parks and turn her over to get oil all around the engine before reconnecting the coil pack and starting her up.
The following user(s) said Thank You: Martinm760
Replied by David Aiketgate on topic Engine Start after a Break
Posted 4 years 9 months ago #192493
Fresh petrol will help too.
Replied by Martinm760 on topic Engine Start after a Break
Posted 4 years 9 months ago #192500
Ok. It has less than a quarter of a tank of fuel. I’ll put another quarter in to help freshen it up a bit. Should be enough?
Last Edit:4 years 9 months ago by Martinm760
Last edit: 4 years 9 months ago by Martinm760.
Posted 4 years 9 months ago #192509
I always fill up with a full tank of Tesco momentum after a long lay over. It is 99ron so higher than Shell or BP premium fuel (and the nearest filling station is 1/4 of a mile away while the others are probably 5 miles away).
The following user(s) said Thank You: SundanceUK, Martinm760
Time to create page: 0.603 seconds
