Ruined my engine on my MG F. Help a novice find a replacement.
- The driving dutchman
Replied by The driving dutchman on topic Re:Ruined my engine on my MG F. Help a novice find a replacement.
Posted 4 years 5 months ago #193386If i were you i'd never get anyway near this garage again. Check a mg or oldtimer club nearby. Plenty of people that can help you way better than those amateurs.
Verstuurd vanaf mijn SM-G950F met Tapatalk
- marshal-beej
- Novice MGer
Replied by marshal-beej on topic Ruined my engine on my MG F. Help a novice find a replacement.
Posted 4 years 5 months ago #193387Hi where in the country are you based ? Good luck with the interviewdjkeenan wrote:
mgtfbluestreak wrote: I would put the mg away for now and self isolate for a while..just too much going on there for a unemployed person to cope with.
Now the lockdown is over I phoned the garage since they hadn't replied to my email. I explained the problem (yellow engine light after a full engine replacement) and that all my OBR reader could tell me was it was an issue specific to the make of car. He replied that he was 99 percent certain that the problem was with the oxygen sensor in the exhaust as OBR readers wont display this specific issue.
He wants me to take it into the garage next week and have it looked at and i'm terrified that i'm gonna now have to buy a new exhaust. What does this mean for me and what should I look out for? Anything I can do before I take it back to him to make sure its the oxygen sensor?
P.s. i've got a job interview this friday, whoop whoop!
Replied by djkeenan on topic Ruined my engine on my MG F. Help a novice find a replacement.
Posted 4 years 5 months ago #193390P.s. I made a spelling mistake in my last post. I meant OBD reader not "OBR reader". Just tested again and can connect but still cant find any fault codes.
- marshal-beej
- Novice MGer
Posted 4 years 5 months ago #193391I only asked because if you were near me in Coventry I could plug my Pscan indjkeenan wrote: I'm based in the county of Rutland which is East Midlands. Thanks for the well wishes I'm hoping the interview goes well
Replied by David Aiketgate on topic Ruined my engine on my MG F. Help a novice find a replacement.
Posted 4 years 5 months ago #193407This will let you see if the problem is an O2 sensor. It will also show any faultcodes and allow you to reset the engine management light.
Something like this
Replied by talkingcars on topic Ruined my engine on my MG F. Help a novice find a replacement.
Posted 4 years 5 months ago #193420djkeenan wrote: Now the lockdown is over
LOCKDOWN IS NOT OVER!
It has been eased but it is not over.
Now, more than ever we need to be carful and we need to be sensible.
Good luck with your interview tomorrow.
Posted 4 years 5 months ago #193474David Aiketgate wrote: If you have an android smartphone you can buy a bluetooth obd2 reader that you can leave plugged into the port on your car. You can download free an app called 'torque' this, when connected to the bluetooth reader will show you live data from your O2 sensors.
Something like this
I use the torque app and a cheap reader similar to that. It finds no faults.
@talkingcars Sorry, misspoke. I meant in the context of car showrooms are no longer in lockdown.
I've just been to my local mechanic, to use his professional bit of kit (before I go back to the garage where the engine was replaced) and he showed me the fault codes (see attached). He cleared the codes and only the vehicle speed sensor issue came back. I know about this problem (speedometer is off by about 4 mph) and i'm not bothered by that. I'm gonna take the car out for a 200 mile drive and see if the engine warning light returns. FYI: the speedo fault code doesn't trigger the engine warning light that's why its currently still off.
Edit: Due to photo compression it makes reading the faults quite difficult. I'm going to list them here as well: p0481, p0480, p0340, p0500, p0420 and p0170
