Coolant leaking all over the garage floor
Coolant leaking all over the garage floor was created by Ericmgf
Posted 4 years 8 months ago #192671
Anyone have any idea what is going on with my car? I have been losing coolant over the past week or two, usually when I have parked the car up overnight in the garage.when I drive my mgf their is no coolant loss, but when I stop the car it appears to empty itself of the coolant expansion bottle.
I have bled the system, bought a replacement cap for the expansion tank and lifted the expansion tank out and checked for hose leaks.
The coolant seems to accumulate on the drivers side rear, and drips down from the chassis rail....could it be a leaky coolant header rail?
I don’t think it’s the head gasket, because I fitted an updated one when I re-built the engine 3 years ago.
Any thoughts gratefully appreciated!
by Ericmgf
Replied by Bob on topic Coolant leaking all over the garage floor
Posted 4 years 8 months ago #192672
I've had something similar it was the water pump.
by Bob
Replied by Steve on topic Re:Coolant leaking all over the garage floor
Posted 4 years 8 months ago #192673
My money is on the water pump too
Sent from my SM-G950F using Tapatalk
by Steve
Replied by Ericmgf on topic Coolant leaking all over the garage floor
Posted 4 years 8 months ago #192674
Any idea how much it is to replace a water pump, presumably the cam belt and tensioner at the same time?
Lost the last engine due to a tensioner failing, whilst the pump is being repaired, may as well get the lot done!
by Ericmgf
Posted 4 years 8 months ago #192675
Contact Rough Luck Racing mobile mechanics, they cover uk wide, at a guess your looking at £250, can't reccomend them enough, give Jon a bell and he will talk you through it.
by Steve
Replied by Ericmgf on topic Re:Coolant leaking all over the garage floor
Posted 4 years 8 months ago #192676
Cheers Steve....really appreciate your help.
by Ericmgf
The following user(s) said Thank You: Steve
Replied by BruceTF135 on topic Coolant leaking all over the garage floor
Posted 4 years 8 months ago #192677
Ericmgf wrote: Anyone have any idea what is going on with my car? I have been losing coolant over the past week or two, usually when I have parked the car up overnight in the garage.when I drive my mgf their is no coolant loss, but when I stop the car it appears to empty itself of the coolant expansion bottle.
I had almost exactly the symptoms you are describing last year. I drove the car about 30 miles - no problem. Parked up and a while later noticed a large puddle under the car.
I topped up, ran the car to duplicate the problem with the engine running for half an hour. Nothing. Then about 10 minutes later coolant started dripping down from the hole towards the rear of the chassis member that runs to the left of the coolant pipes.
Investigation revealed that there was wetness inside the tunnel at the back of the car. Pulling out the box between the seats enabled me to stick an arm in and feel wetness at the back, under the petrol tank, near where the heater pipes pass out into the engine bay.
With advice, it was decided the problem was excess pressure. I replaced the pressure release thermostat (PRT), which is straightforward.
Since then, I have had no further problem.
I would add that I had the cambelt, tensioner and pump replaced about a year previously, so never even considered the water pump.
Replied by The driving dutchman on topic Re:Coolant leaking all over the garage floor
Posted 4 years 8 months ago #192683
Good that its solved. And good to keep.in mind! Thanks for sharing.
Verstuurd vanaf mijn SM-G950F met Tapatalk
Posted 4 years 5 months ago #193365
Finally got the problem resolved...perished water pump gasket!...got the pump replaced and cam belt also for £270 by the brilliant team at Rovetech in Stockton on Tees....many thanks guys!
by Ericmgf
The following user(s) said Thank You: David Aiketgate, Bob
Time to create page: 0.520 seconds
