Door mirror internal grommet fix
Most of us have needed 1 or 2 of these in our time ... & flea bay have them at a prohibitive 4,5 ...£6 each or even a pair.
Try these , designed for furniture in the main, these are £1.50 or so for 20 ... most smaller diy stores stock these. ..so even if a couple drop out or blow away at that money its no big deal a little glue or mastic should sort that though......see photo
Last Edit:4 years 5 months ago
by Fil6909
Last edit: 4 years 5 months ago by David Aiketgate. Reason: Inserted photo
This got me thinking as the missing grommets has always annoyed me. The hole is 1/2” ( British car after all), what could I use to punch 1/2” plugs? Answer is 15mm copper pipe filed to have a sharp edge. I’ve punched the plugs out of the centre of 1” grommets, but any other suitable plastic item could be used.
by Gavin207
That's good ..snugger fit than the ones I used .
by Fil6909
Time to create page: 0.495 seconds
