Hi All
If you own a ScanGuage you will know the difficulty in locating it on a TF (and I assume an F).
So, I took the radical approach of modifying the centre consul air vents (closed them off) and fitting it in a modified vent mount! (some will not like that).
However, as I only use the car in the summer months, garaged over winter, and therfore never seem to use the centre vents. It was the best place to fit the SacnGuage.
I did retain the original vent set-up so it can be put back to original. But I must say I am very pleased with the result>
Last edit: 4 years 4 weeks ago by
Raccoon.
