Mg Tf Exhaust heat sheild
- trevtherevs
- Apprentice MGer
Any suggestions ideas greatly accepted.
I have seen a lot of posts regarding the exhaust silencer heat shield dropping to bits, along with comments about leaving it off or its an original part so must have been required.
Mine is also crumbling completely apart all along the two ends where it bolts to the underside of the car. I did see you can get stainless steel replacements from Rimmer Bro at £99.
However, I was hoping to try and repair the original and save a bit of cash. I was drawn towards perhaps wrapping the two ends in exhaust mesh and stiffening up both these edges and pop riveting this to the old shield.
https://www.carbuilder.com/uk/embossed-aluminium-heat-shield-1000mm-x-1000mm
by trevtherevs
Mike Satur has one on clearance for £86.96 here
https://www.mikesatur.co.uk/MGF-and-MGTF-Stainless-Steel-Exhaust-Heat-Shield-by-Mike-Satur
You'll struggle to attach anything to the existing shield which is a fibre based item. I used some ali heatshield material from a scraped mini but any modern will have something usable if you want to keep the cost down.
Last Edit:4 years 2 weeks ago
by MGmike
Last edit: 4 years 2 weeks ago by MGmike.
I took mine off, as it was falling off anyway, about a year ago. ive had no issues since, but i dont carry frozen things in my boot etc. I have a roll of ''nimbus'' heat shield that ive use for similar things before. I plan to shape and bolt it to the original fixings, but i havent found the will power to go under and do it yet.
by vdv
- trevtherevs
- Apprentice MGer
That will power seems to ebb and flow with the weather, and more flow in my case as well
by trevtherevs
I used Aluminium filler, from eBay, normally used for alloy wheel scuffs. It sets really hard and adheres really well, you can file it to shape when set.
Mike
Mike
by gloscs
Time to create page: 0.568 seconds
