MGTF Rear Long Trailing Arms
MGTF Rear Long Trailing Arms was created by Fisher
Posted 4 years 1 week ago #194640
Hi All
Looking to replace my Rear Trailing Arms (Long) - What a price from Rimmers!
As the arms can be re-furbished i.e. cleaned and repainted. I have been looking at the possibility of changing the bushes. However, cannot find anyone on the internet who supplys them!
The railing arms are RGD000620 and RDG000630 are the ones I am looking at.
Someone must make replacement bushes poly or even rubber. Anyone refurbished these parts? Where did you get the bushes?
Robert
by Fisher
Replied by Bob on topic MGTF Rear Long Trailing Arms
Posted 4 years 1 week ago #194641
by Bob
Replied by talkingcars on topic MGTF Rear Long Trailing Arms
Posted 4 years 1 week ago #194645
Hi Robert
I often find the part number on the Rimmers website and then do an internet search using the part number to find the best prices, I think I got the trailing arms for half the Rimmers price.
Replied by Fisher on topic MGTF Rear Long Trailing Arms - Updated
Posted 4 years 5 days ago #194648
Hi All
Thought an update would be appreciated. Yes (Bob - Thanks) you can get the trailing arm bushes - Borge & Beck Link Assy Bush - Rover, MG BSK 7494 for £33.46 the pair.
Now for the outer trackrod end type jounts. Came across a posting on the MG-Rover Forum by a chap called Adam MGTF - 2009:
https://www.mg-rover.org/threads/rear-trailing-track-rod-end-for-tf-i-have-found-it-and-saved-everyone-%C2%A3150.451051/
He located joints, but never confirmed that they will fit the taper joint. Theses were:
Fai Joints SS699 /SS698, so have purchased one (£11.00).
On the surface they look OK. but still need to check taper compliance, which I can only do next week when I borrow a spare hub from a friend. So will update on that. Plus dimension details.
If it works will save approx £110.00 on refurbed replacements.
Anyone go any thoughts?
Robert
Last Edit:4 years 5 days ago by Fisher
Last edit: 4 years 5 days ago by Fisher. Reason: spelling
Posted 3 years 11 months ago #194707
Hi All - Thought I would close-off this thread. Well only part success has been achived!
First the wishbone/trailing arm bush, which I thought would be the easiest (sorry Bob). Is only for the shock absorbers, does not, and will not fit the training arm. Marking on the original part indicated it was a TRW Joint 024 0007 633 009 653 - Which is not manufactured anymore. Those in the know have told me that the bush is metallastic, which means the inner part of the bush needs to move with the travel of the suspension. So, a polybush could not be used. Polybush never even replied to my query so have forgotten that avenue unless someone informs me with further recommendations. Finally, did look a rose-joints but could not find a suitable replacement ( maybe someone else can pick this up?)
Secondly, the outer joint is a standard track-rod end. Original was also a TRW joint 022 0002 312 009 - Again, not manufactured any more. However the Fai Joints SS699 /SS698. fit perfectly, and the taper matches the hub.
So, yes the outer joints can be replaced. But the inner not at this stage.
Finally, my thread on the shorter trailing joints.
https://www.the-t-bar.com/forum/9-mgf-tf-pitstop/97262-another-rear-trailing-arm-question-but-the-short-one-this-time
Yes, the adjustable ones can replace the fixed. So that thread is also now closed.
by Fisher
The following user(s) said Thank You: David Aiketgate, Bob
Replied by Seamus on topic MGTF Rear Long Trailing Arms - Updated
Posted 3 years 11 months ago #194735
I know that you have closed the post but they can be bought a lot cheaper than Rimmers. I bought mine from MGFnTFBITZ.
www.mgfntfbitz.co.uk
MG TF NEW RGD000630 N/S REAR TRAILING ARM TIE BAR LINK FREE 24 HR DELIVERY
Completed
Last Edit:3 years 11 months ago by Seamus
Last edit: 3 years 11 months ago by Seamus. Reason: Added web address
Posted 3 years 11 months ago #194736
Hi I was not looking at buying, but refurbing.
Robert
by Fisher
Time to create page: 2.635 seconds
