Cat for 2000 MGF
Cat for 2000 MGF was created by Postman87
Posted 3 years 11 months ago #194823
Afternoon all. Recent purchase of a 2000 MGF, without full inspection due to covid, has paid off. MOT failure was emissions and a stuck handbrake cable. So not much to do. Searching for a cat is giving me a headache. It's pre 2001 but wish to fit an approved type. Keeps coming up in notes that the cat will only fit non OBD. Thought they all had OBD or am I missing something. Looking at EEC RV8010T and BM90440H. Grateful for any advice.
Replied by David Aiketgate on topic Cat for 2000 MGF
Posted 3 years 11 months ago #194824
Two types of cat. One pre mems3, one post mems3. Later setup has two lambda sensors. Pre and post cat. Also the later cat has a 90degree bend after the cat.
So get whichever type is already fitted.
Pre mems3 cat
Post mems3 cat
Last Edit:3 years 11 months ago by David Aiketgate
Last edit: 3 years 11 months ago by David Aiketgate.
The following user(s) said Thank You: Postman87
Replied by Postman87 on topic Cat for 2000 MGF
Posted 3 years 11 months ago #194831
Thanks for that David. I now understand the notes on cats and have ordered the correct one.
Replied by talkingcars on topic Cat for 2000 MGF
Posted 3 years 10 months ago #194847
Interestingly a specialist garage replaced the cat on my MEMS2.0 car with one of similar size but it had a boss for a sensor so they fitted a dead sensor and cut the top off.
Posted 3 years 10 months ago #194851
Apparently you do get them with sensors hence my reluctance to order before fully understanding. In your case they possibly had wrong part and was easier to do what they did rather than change or wait for the correct part. Would work just the same.
Posted 3 years 10 months ago #194858
Don't be confused here, guys!
James is saying that they fitted a SIMILAR cat that had a sensor port to his mk1 car, not fitted a later mgf/tf cat.
In the original exhaust layout, the back box has a I80 degree bend to mate to the straight cat.
In the later layout the cat has a 90 degree bend with a sensor port in it. The back box has a 90 degree bend too.
You can buy an adapter, a 90degree bend with a sensor port in it, from mike satur that converts a mk1 cat to fit a mk2 exhaust back box.
This is what I have, because at the time I could get an original straight cat and buy the adapter cheaper than buy a mk2 cat!
Posted 3 years 10 months ago #194860
Apologies for the confusion. I should have been clearer I was talking about the straight cat for the earlier model which comes with and without Lambda sensor hole
Last Edit:3 years 10 months ago by Postman87
Last edit: 3 years 10 months ago by Postman87.
The following user(s) said Thank You: David Aiketgate, Keymaster
Posted 3 years 10 months ago #194872
Postman87 wrote:
This is what I have.
The following user(s) said Thank You: David Aiketgate, Fisher
Time to create page: 0.504 seconds
