Stainless steel manifold and downpipe
Replied by Cobber on topic Stainless steel manifold and downpipe
Posted 3 years 10 months ago #194928"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Replied by Postman87 on topic Stainless steel manifold and downpipe
Posted 3 years 10 months ago #194929I'm more interested in longevity than shinny shinny. A case of fit and forget. There a number of good prices at the moment for stainless steel manifolds and downpipes. I looked at a cheaper Toyosports but from experience I'm reluctant to purchase due to fitting issues in the past.
Important question is it worth it putting on stainless steel and will it last much longer.
Replied by David Aiketgate on topic Stainless steel manifold and downpipe
Posted 3 years 10 months ago #194930Apart from that, no problems.
Incidentally if you are replacing both parts, go for the 6 bolt version rather than that 4 bolt flange.
Much better design and is a direct replacement.
Posted 3 years 10 months ago #194931I take it the manifold to engine is exactly the same on both versions. The one on it just now is the 4 bolt at the flange between the manifold and the downpipe.
Posted 3 years 10 months ago #194932The 4 bolt manifold to downpipe was changed to 6 to solve numerous leaking exhaust gas issues at that point.
The pipework flow of the 6 bolt manifold is slightly different (improved) as you can see in the pics.
Posted 3 years 10 months ago #194937Please Log in or Create an account to join the conversation.
Replied by talkingcars on topic Stainless steel manifold and downpipe
Posted 3 years 10 months ago #194952If so I went from the O/E 4 bolt to 6 bolt on my mk1 VVC.
You can fit a VVC exhaust to a non VVC model, the outlet on the head is the same.
Posted 3 years 10 months ago #194959<quote>Is this a rebrand of the Toyo exhausts as I can't see Toyo on eBay.
You can fit a VVC exhaust to a non VVC model, the outlet on the head is the same. </quote>
You could be right about Toyo rebrand. Gravity is just Japspeed in a different guise. They supply but don't maqnufacture parts.
As for Toyosport, they are still on ebay. My choice was between them and Gravity. In the end i went for the 4 bolt gravity as the the 6 bolt Toyo was listed as a cat delete manifold so i decided to go like for like. Could be with me tomorrow as they use a 24 hour service, my sister company Parcelforce. May take longer due to volume of parcels they are dealing
with. Not in a hurry , not required for MOT and they wife has me decorating anyway.
Posted 3 years 10 months ago #194969They are slightly incorrect, the fron't mounted K series have a pre-cat in the downpipe, the rear engined MGF/TF don't except for the LE500.Postman87 wrote: In the end i went for the 4 bolt gravity as the the 6 bolt Toyo was listed as a cat delete manifold so i decided to go like for like.
Replied by Devinci on topic Stainless steel manifold and downpipe
Posted 3 years 10 months ago #194971Please Log in or Create an account to join the conversation.
Posted 3 years 10 months ago #194973In the photo for a 6 bolt, listed as cat delete, you could see the hole for the sensor in the downpipe. In the end i just chickened out in case there were any problems. This was even after David explained to me the benefits of the 6 bolt version. I've always had a problem with the compatibility on ebay, i never trust it. The parts have now arrived and are stored in my garage until I get around to fitting them.talkingcars wrote:
