Stainless steel manifold and downpipe
Replied by talkingcars on topic Stainless steel manifold and downpipe
Posted 3 years 10 months ago #194991Not too easy in the car but the head can come out so time it for when you get a new head gasket.Devinci wrote: Got one on the shelf , but i am still in doubt, iam afraid to loosen the bolts where the manifold is attached to the block. A little scared, if one breaks, then what? Can that still be repaired without removing the entire engine from the car?
Posted 3 years 10 months ago #194992Ask here before you buy, several of us have mixed it up with different partsPostman87 wrote:
................I've always had a problem with the compatibility on ebay, i never trust it........
My mk1 VVC MEMS 2.0J has a MEMS 3 manifold and downpipe to a Land Rover cat and mk1 tailbox.
It has TF 2002 subframes with MY05 suspension and MGF subframe mounts.
The gear cables are mk2 F with a modified TF lever mechanisum.
Door cards are TF as are the door mirrors.
A bit of a frankin F! LOL
Posted 3 years 3 days ago #197690Hi talkingcars, do you happen to know if the six bolt version will fit the LE500? It has the hole for the Lambda sensor but the supplier seems to think that it wouldn't fit my 2008 LE500. It will obviously remove the pre-cat original set up which seems restrictive even after a remap. Thanks
Sorry Pete, I am not sure but IIRC the LE500 has a pre-cat and different engine management.
- bryan young
Replied by bryan young on topic Stainless steel manifold and downpipe
Posted 3 years 3 days ago #197695Please Log in or Create an account to join the conversation.
