Issues with XPart suspension (Suplex)
Hi and welcome to the forum
Are you still running on hydragas?
James
James
by talkingcars
Replied by David Aiketgate on topic Issues with XPart suspension
Posted 3 years 9 months ago #195176
This isnt the Suplex, spring in a can, system is it?
If so please read my posts about Suplex...
- Bovrilman68
- Novice MGer
Spring in a canister, i say Suplex cause it looks like it used suplex springs
by Bovrilman68
- Bovrilman68
- Novice MGer
Posted 3 years 9 months ago #195179
Yeah, I thought it sounded like the usual suplex problems. I have written reams about these particular items, none of it complimentary.
Search suplex on the forum.
Suffice it to say that the dampers are not fit for purpose, due to being copies of the original mgf damper which was designed to work with hydragas, not coil springs. Then bodged to make them sort of work...
The clonking is most likely the spring seat contacting the canister.
You can look forward to your rear damper top mounts cracking away from the panel...
Posted 3 years 9 months ago #195180
https://www.the-t-bar.com/forum/9-mgf-tf-pitstop/57934-suplex-suspension-my-experience-it-s-not-good
Have a read of the above thread...
Apologies for missing photos...
Last Edit:3 years 9 months ago
by David Aiketgate
Last edit: 3 years 9 months ago by David Aiketgate.
- julianfoulger
Fortunately, 2 years ago I fitted a new set of Trophy spheres all round so still on hydragas.
Any longterm feedback on the Mike Satur solution (the suplex alternative)?
Posted 3 years 9 months ago #195196
Ive not heard any negative reports on the Mike Satur system, or the Aussie system. Only positive so far...
I've installed Mike Satur's FCCKit in both of our Fs. I installed one in February, 2019 and the other in June, 2019, so two driving seasons so far and my wife and I are very impressed with the ride quality that the coilover kit provides.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Last edit: 3 years 9 months ago by mowog73.
Time to create page: 0.583 seconds
