Re:New leak found
New leak found was created by mrtsbrother
Posted 3 years 9 months ago #195187
Hi all, I've discovered that my floor appears to be leaking. I've had the interior stripped out for a while as I'm trying to get it as water tight as possible. I'd noticed tiny pools on the floor adjacent to the central section by the rear bulkhead on both passenger and drivers side. I assumed it was running from elsewhere but I saw the water reappearing as I dried it. It's a new one on me but I've sealed it up now so fingers crossed it's sorted. Might have something to do with the slight incline that a park on?
Sent from my Pixel 2 XL using Tapatalk
Replied by David Aiketgate on topic New leak found
Posted 3 years 9 months ago #195193
Have you checked the integrity of the heater pipes that run in the centre console?
Replied by mrtsbrother on topic Re:New leak found
Posted 3 years 9 months ago #195206
David Aiketgate wrote: Have you checked the integrity of the heater pipes that run in the centre console?
I'm not losing any fluids and have stainless pipes beneath if that's the ones you're referring to?
Since the sealant no pools so far, although it hasn't rained all that heavily since then..... Thanks for the suggestion!
Replied by David Aiketgate on topic Re:New leak found
Posted 3 years 8 months ago #195208
No, I meant the heater pipes. They run to the heater matrix through the centre console.
Replied by mrtsbrother on topic Re:Re:New leak found
Posted 3 years 8 months ago #195225
No leaks in the centre console... But the little oils came back today, I think because I jacked the front up to do the hinges! I'm thinking more sealant is needed 😬
Time to create page: 0.485 seconds
