DRLs
DRLs was created by Kimbies
Posted 3 years 8 months ago #195273
Hello everyone.
I'm new to this forum, having obtained the F only a few months ago. I have noted a number of posts around the place on Daytime Running Lights and was wondering what you thought of this idea. It works well on my B, but I am a little concerned that it might disturb some of the electronics - this is the most modern car I have ever owned.
The left hand relay detects that the engine is running, and the right hand one powers the head lights,
Thanks, Kim
by Kimbies
  • Away
Replied by Cobber on topic DRLs
Posted 3 years 8 months ago #195274
I don't see it as a problem
Replied by David Aiketgate on topic DRLs
Posted 3 years 8 months ago #195278
This might help.
https://www.the-t-bar.com/forum/54-how-tos/96076-daytime-running-lights-cob-led-halo-s-for-the-tf#184927
Replied by talkingcars on topic DRLs
Posted 3 years 8 months ago #195284
The MGF uses the oil pressure switch to control the heated rear window circuit so there is a possibility that this set up may affect that.
Personally I would use a feed from the ignition position 2.
James
Replied by Kimbies on topic DRLs
Posted 3 years 8 months ago #195290
Thank you.
David, I did read Sundance's post and thought "I like that". I even bought a set of the halo lights before I realised the headlights on the MGF were unsuitable. NEWBIE!
And James, thank you I didn't know that. I don't have a heated rear window, so that isn't an issue. I will be using IGN II for power, but I need a signal that the engine is actually running.. I was going to use the alternator light, since I designed this for my MGB, and as you may know, the B doesn't have an oil pressure switch.
by Kimbies
Posted 3 years 8 months ago #195294
If you're not going to get a heated rear window you may be able to take oil pressure switch signal from the HRW circuit and use it for the DRL.
If you haven't found it yet there are wiring diagrams in downloads under the community tab at the top of every page of the website.
Replied by Steve on topic Re:DRLs
Posted 3 years 8 months ago #195298
Don't you also need a relay to cut power to the drls when the headlights are on ?
by Steve
Replied by SundanceUK on topic DRLs
Posted 3 years 8 months ago #195299
There are many dedicated control units that are available on Ebay that will switch or dim the DRL's depending on how your headlights are operating. I also added a couple of isolating relays to cut each side out if the indicators are flashing. With the indicators close to the Halo rings, this is adviseable as the brightness of the LED's will obscure the indicator operation.
Sundance
Time to create page: 0.541 seconds
